Hi. I am at the step of loading the updated firmware to my board. I have already done the Tiny Booter step. I do not see MF Deploy anywhere. Where is that exactly. I did not see it in the STDFU Tester.
Thanks.
Thanks.
C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Tools
Ok. I am there. It does not see my Cerberus as a device. Do I need to restart or something after doing the earlier steps?
Thanks.
What do you see under device manager?
It is blank. I have USB selected and I am pinging it.
When you used STDFU Tester you needed to put it in boot mode. Did you remove the jumper that activated the boot mode?
