I hope I can clearly state my confusion so here it goes. I’ll use the pins I’m using as an example.
The schematic for the Cerbuino Bee shows that the processor pins PB0 and PB1 to be at pin location 26 and 27.
http://www.ghielectronics.com/downloads/schematic/FEZ_Cerbuino_Bee_SCH.PDF
This is consistent with the ST Micro documentation:
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/DM00037051.pdf
However, the Cerb mapping defines them to be Cpu.Pin 16 and 17.
namespace GHI.Hardware.FEZCerb
// Summary:
// Pin definitions for FEZCerb.
public class Pin
// Summary:
// A value indicating that no GPIO pin is specified.
public const Cpu.Pin GPIO_NONE = -1;
// Summary:
// Digital I/O.
public const Cpu.Pin PB0 = 16;
// Summary:
// Digital I/O.
public const Cpu.Pin PB1 = 17;
// Summary:
// Digital I/O.
public const Cpu.Pin PB10 = 26;
// Summary:
// Digital I/O.
public const Cpu.Pin PB11 = 27;
public Pin();
If you wire up a LED to PB0 on the Cerbuino Bee, referencing Cpu.Pin.PB0 will light up the LED.
So, I don’t understand the relationship of the Cpu.Pin to the actual hardware pins. I thought they should be the same (eg. PB0 should be Cpu.Pin 26).
The reason I’m trying to understand this is that I have a custom board that has a LED wired to pin 26 and I can’t get it to light up. I don’t know if it’s an electrical or code problem and whether I should reference the FEZCerb.Cpu.Pin.PB0 (pin 16) or hard coded pin 26. Neither work right now. To complicate things I need PWM and PWM 5 is assigned to PB0 so I hope that GHI is correct and that I have an electrical problem.
Did any of this make sense?
