FEZ Cerb 40 custom
I’ve been playing with a design which is based heavily on the cerb40. However I plan to just drop in the STM32F4 processor instead of using the fez cerb 40 breakout board.
Since everything is open source it will be possible to flash the firmware and get it to run .net mf 4.2 right?
I remember reading something to the effect that there is a GHI boot loader which loads up the tiny boot loader. Is this still true? If so, how do you get the GHI boot loader on a blank STM32F4?
Yes you can just do that, just make sure you attribute properly as outlined on wiki and in the license.
I sure will :slight_smile: So you only need the tiny boot loader?
We provide you with everything you need A to Z.
