I made a utility that will update a FEZ to the latest firmware. Tested with exactly one FEZ Domino on exactly one machine.
Code is available at GitHub - bcr/FezBootloaderUtil: FEZ bootloader utility. Good for updating firmware.
In general, you can just put your FEZ board in bootloader mode and run it, and the magic happens.
Two potential limitations right now:
- It looks for the USBizi firmware in a fixed location, namely “C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\USBizi\Firmware\USBizi_CLR.GHI”. This may not work on every machine.
- It looks for a USB device with a description of “GHI Boot Loader Interface”. If it doesn’t find that, it stops.
Happy to hear any guidance about how to address these potential limitations.
Principles of Operation
- Find the COM port for the FEZ in bootloader mode
- Transmit the new firmware using XMODEM-1K to the board over the COM port
One clever bit (well, I think it’s clever) that I found was the serial port identification code:
private SerialPort OpenFezBootloaderSerialPort()
var searcher = new ManagementObjectSearcher("select DeviceID,MaxBaudRate from Win32_SerialPort where Description = \"GHI Boot Loader Interface\"");
foreach (var obj in searcher.Get())
return new SerialPort((string) obj["DeviceID"], (int) (uint) obj["MaxBaudRate"]);
throw new Exception("Unable to find FEZ device. Is it in bootloader mode?");
This uses Windows Management Instrumentation (WMI) to find the associated COM port with the FEZ, and then creates a SerialPort
object preconfigured for the MaxBaudRate
advertised by the device.
Comments welcome. I may poke at it some more and do some other bootloader-related activities. Now that XMODEM-1K works, it should be fairly simple to add in loading / reading managed application code.
