[quote]1. Can I use a database for the dropbox menu and also for the data that will show up if an option is chosen? If yes, how?
[/quote]
I poked around the documentation and looks like the dropdown menu does not have a method to add items at runtime. This is work in progress and you should see something soon from GHI.
[quote]2. Can I use the directional pad as a controller aside from the touch feature that the Glide offers?
[/quote]
I think you can program the logic for this. Look at http://www.ghielectronics.com/glide/example/5/ as an example and see how the events are passed.
ArrayList options = new ArrayList()
// Each object array contains Label, Data
new object[2] { "Option #1", 1 },
new object[2] { "Option #2", 2 },
new object[2] { "Option #3", 3 },
new object[2] { "Option #4", 4 },
new object[2] { "Option #5", 5 }
list = new List(options, 150);
You can either keep the options in the XML, or use both XML and dynamic content, or just dynamic content. If you choose the later be sure to remove the options from the XML like this
Architect, no I haven’t. Thanks for the link though. Should I just use this library?
Btw, I have done database on Visual Studio Windows Application format, is the format the same as for NETMF?
@ Architect, sorry to bother you. but I don’t know how to start using the link you gave me. I downloaded it already. And now, I’m stuck on how to use it in my program. I badly need you help and it’s greatly appreciated! I hope you’ll reply Thanks!
I just tried the example in the link you gave me. Anyway, first am i doing this right.? Can you check the solution explorer.? as well as the breakpoint because of the unhandled exception. Thanks
This error comes up whenever i tried to run it.
An unhandled exception of type ‘System.NotSupportedException’ occurred in GHIElectronics.NETMF.SQLite.dll
