Now I noticed that, temperature and humidity sensor does not measure correctly, temperature is always -39.65 and humidity -2.69. Has anyone this problem?
Also I don’t know, how to change display orientation. I tried
displayT43.Orientation = GTM.Module.DisplayModule.DisplayOrientation.UpsideDown;
but it does not work. Any suggestions?
@ miroga - The orientation is not properly saved when using that method. It will be fixed in the next SDK. In the mean time, you can use our Configuration class directly.
What board are using the temperature and humidity sensor on? Have you tried different sockets and cables? Also a different mainboard if you have one.
I was looking to do some of my network tests ( The Great Network Shootout https://www.ghielectronics.com/community/forum/topic?id=14607 ) but I’m having some issues. For example using a Spider with an J11D and ThingSpeak, I’m running into a socket error in the ThingSpeak library (which I wouldn’t have thought would be affected by going to 4.3)
// open socket e connect to the host
using (this.socket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp))
this.socket.Connect(this.hostIpEndPoint); <- blow up here with a socket error
Nothing more. It seems to be a call from within the PPP code that calls the Length function on the serial port and it fails as it’s not supported. If I call this function in my own code on the same or any serial port, I get the same exception.
