90% of your challenge will be finding a way to have an image and attach that to a tweet. If you can find the API or REST call to allow that, then you have a chance. OAUTH challenges aside of course
the other 10% of your challenge will be capturing an image in a format usable by above API. You will likely need a JPG or PNG, you won’t be able to have a BMP, so you will need to have some way to capture that reasonably. Perhaps that’s 20% and the earlier bit is 80%. Or maybe the balance is 50:50, but either way these two are what I see as the most challenging pieces
Check out MicroTweet on CodePlex and Architect improved upon it with a FEZ friendly version that’s available through his website as well. I don’t think either do pics yet but I believe Architect worked out the OAuth issues and would probably love a TwitPic contribution
@ ShapingStuff check out the Twitter API page, it’s pretty straight forward, all the calls are blindingly simple once OAuth is out of the way. You should be able to copy/paste one of the existing calls and simply change the parameters to fit the new call.
@ skewworks, speaking of OAUTH, I wasn’t sure what option to explore on the dev.twitter.com to set that up based on your code. I assume it’s the “PIN” method, since that talks about not being able to access a browser (which I interpret as really saying there’s no UI to get to a browser/embedded twitter page). Can you confirm thats right?
