I have 2 FEZ Spider boards, the 1st one i was working with for about a week and it stopped. currently there is a red LED flashing on the USB Client DP but the main board is dead, no power light or any other form of activity.
Then i took my second unit out of its box and plugged it in. Did the whole firmware update procedure and uploaded my code to it, now on this one the reset button does not work and it does not pickup the SD card.
Go through the firmware reset process again, and just deploy a simple test application to it. See if that works (you may need to do several resets to get the device to appear to respond to be able to deploy the firmware if your app is not behaving well)
if you are referring to the first board, then no, can’t connect to board in any way, and it does not power on.
did try to ping it but no response at all.
if you are referring to second board, then the board works fine with current code, except for the fact that the reset button on the board does not work.
Is it stuck or it is pushed down but doesn’t reset the board? I have seen it where buttons get stuck after reflow process and a bit extra pressure get it unstuck. Try to press it hard few time, if not luck contact GHI for exchange.
