Before I tested on the bike I built a small simple pulse generator circuit around a 555 ic. I was able to get this up to about 350 kHz.
On the bike, being a 2 cylinder, I would get 2 pulses per revolution. The pulse generator therefore can give me an R.P.M. reading of up to about 10500 R.P.M.
With this pulse generator connected to the Panda II it gives me very stable readings with no false interrupts.
So, full of hope I went to connect it to the bike but needless to say I was quite dissapointed. Connected to the bike I got very unstable reading which indicates I’m getting lots of false interrupts.
Below is the output I get at a fairly stable idle of around 900 R.P.M.
Just look at the very first number for the R.P.M. I get. The second number incidentally is supposed to be the speed but with the rear wheel standing still it should be stable at 0 which is also not the case.
2179 - 1 - 0.00076097560975609761 - 0.00076097560975609761
1487 - 1 - 0.00076097560975609761 - 0.00076097560975609761
1269 - 1 - 0.00076097560975609761 - 0.00076097560975609761
1339 - 1 - 0.00076097560975609761 - 0.00076097560975609761
1472 - 1 - 0.00076097560975609761 - 0.00076097560975609761
1431 - 1 - 0.00076097560975609761 - 0.00076097560975609761
1241 - 2 - 0.0015219512195121952 - 0.0015219512195121952
1509 - 2 - 0.0015219512195121952 - 0.0015219512195121952
1554 - 2 - 0.0015219512195121952 - 0.0015219512195121952
1562 - 2 - 0.0015219512195121952 - 0.0015219512195121952
1511 - 2 - 0.0015219512195121952 - 0.0015219512195121952
1133 - 2 - 0.0015219512195121952 - 0.0015219512195121952
1133 - 2 - 0.0022829268292682927 - 0.0022829268292682927
1331 - 2 - 0.0022829268292682927 - 0.0022829268292682927
1525 - 2 - 0.0022829268292682927 - 0.0022829268292682927
1327 - 2 - 0.0022829268292682927 - 0.0022829268292682927
1489 - 2 - 0.0022829268292682927 - 0.0022829268292682927
1265 - 2 - 0.0022829268292682927 - 0.0022829268292682927
1265 - 3 - 0.0030439024390243904 - 0.0030439024390243904
1453 - 3 - 0.0030439024390243904 - 0.0030439024390243904
1303 - 3 - 0.0030439024390243904 - 0.0030439024390243904
1499 - 3 - 0.0030439024390243904 - 0.0030439024390243904
1628 - 3 - 0.0030439024390243904 - 0.0030439024390243904
1590 - 3 - 0.0030439024390243904 - 0.0030439024390243904
1304 - 3 - 0.0038048780487804881 - 0.0038048780487804881
1540 - 3 - 0.0038048780487804881 - 0.0038048780487804881
1781 - 3 - 0.0038048780487804881 - 0.0038048780487804881
1648 - 3 - 0.0038048780487804881 - 0.0038048780487804881
1464 - 3 - 0.0038048780487804881 - 0.0038048780487804881
1632 - 3 - 0.0045658536585365854 - 0.0045658536585365854
1584 - 3 - 0.0045658536585365854 - 0.0045658536585365854
1645 - 3 - 0.0045658536585365854 - 0.0045658536585365854
1639 - 3 - 0.0045658536585365854 - 0.0045658536585365854
1202 - 3 - 0.0045658536585365854 - 0.0045658536585365854
1682 - 3 - 0.0045658536585365854 - 0.0045658536585365854
1682 - 3 - 0.0053268292682926831 - 0.0053268292682926831
1617 - 3 - 0.0053268292682926831 - 0.0053268292682926831
1700 - 3 - 0.0053268292682926831 - 0.0053268292682926831
1601 - 3 - 0.0053268292682926831 - 0.0053268292682926831
1328 - 3 - 0.0053268292682926831 - 0.0053268292682926831
1626 - 3 - 0.0053268292682926831 - 0.0053268292682926831
1626 - 3 - 0.0060878048780487809 - 0.0060878048780487809
1584 - 3 - 0.0060878048780487809 - 0.0060878048780487809
1616 - 3 - 0.0060878048780487809 - 0.0060878048780487809
1544 - 3 - 0.0060878048780487809 - 0.0060878048780487809
1630 - 3 - 0.0060878048780487809 - 0.0060878048780487809
1588 - 3 - 0.0060878048780487809 - 0.0060878048780487809
1741 - 3 - 0.0068487804878048786 - 0.0068487804878048786
1477 - 3 - 0.0068487804878048786 - 0.0068487804878048786
1678 - 3 - 0.0068487804878048786 - 0.0068487804878048786
1725 - 3 - 0.0068487804878048786 - 0.0068487804878048786
1476 - 3 - 0.0068487804878048786 - 0.0068487804878048786
1302 - 3 - 0.0076097560975609763 - 0.0076097560975609763
1494 - 3 - 0.0076097560975609763 - 0.0076097560975609763
2381 - 3 - 0.0076097560975609763 - 0.0076097560975609763
1652 - 3 - 0.0076097560975609763 - 0.0076097560975609763
1648 - 3 - 0.0076097560975609763 - 0.0076097560975609763
1596 - 3 - 0.0076097560975609763 - 0.0076097560975609763
1596 - 3 - 0.008370731707317074 - 0.008370731707317074
1568 - 3 - 0.008370731707317074 - 0.008370731707317074
1677 - 3 - 0.008370731707317074 - 0.008370731707317074
1618 - 3 - 0.008370731707317074 - 0.008370731707317074
1331 - 3 - 0.008370731707317074 - 0.008370731707317074
1521 - 3 - 0.008370731707317074 - 0.008370731707317074
1213 - 3 - 0.0091317073170731709 - 0.0091317073170731709
1588 - 3 - 0.0091317073170731709 - 0.0091317073170731709
1265 - 3 - 0.0091317073170731709 - 0.0091317073170731709
1694 - 3 - 0.0091317073170731709 - 0.0091317073170731709
1539 - 3 - 0.0091317073170731709 - 0.0091317073170731709
1687 - 3 - 0.0098926829268292677 - 0.0098926829268292677
1622 - 3 - 0.0098926829268292677 - 0.0098926829268292677
1667 - 3 - 0.0098926829268292677 - 0.0098926829268292677
1657 - 3 - 0.0098926829268292677 - 0.0098926829268292677
1234 - 3 - 0.0098926829268292677 - 0.0098926829268292677
1655 - 3 - 0.0098926829268292677 - 0.0098926829268292677
1839 - 3 - 0.010653658536585365 - 0.010653658536585365
2178 - 3 - 0.010653658536585365 - 0.010653658536585365
1362 - 3 - 0.010653658536585365 - 0.010653658536585365
1471 - 3 - 0.010653658536585365 - 0.010653658536585365
1621 - 3 - 0.010653658536585365 - 0.010653658536585365
1621 - 3 - 0.011414634146341461 - 0.011414634146341461
1670 - 3 - 0.011414634146341461 - 0.011414634146341461
1777 - 3 - 0.011414634146341461 - 0.011414634146341461
1675 - 3 - 0.011414634146341461 - 0.011414634146341461
1631 - 3 - 0.011414634146341461 - 0.011414634146341461
1585 - 3 - 0.011414634146341461 - 0.011414634146341461
1585 - 3 - 0.012175609756097558 - 0.012175609756097558
1463 - 3 - 0.012175609756097558 - 0.012175609756097558
1674 - 3 - 0.012175609756097558 - 0.012175609756097558
1713 - 3 - 0.012175609756097558 - 0.012175609756097558
I now do not know whereto from here and must admit I do feel fairly dissapointed.
