Hi All,
We recently witnessed an apparent hardware failure on an EMX and are wondering if anyone has seen similar before.
Current draw on RTC_VBAT exceeds 400mA, and the resistance to ground through the RTC_VBAT (pin 28) when the unit is off is only 1.7 ohms.
Has anyone seen this type of failure before?
It happened after the EMX sustained a shock load from falling to the floor.
Are there any shock or vibration specifications for the EMX?
Thanks for your help.
-Steve
