The following program starts a main thread and two worker threads. In the second worker thread every 10 seconds an exception is thrown.
The mechanism is used in a program where the first worker thread is reading from serial port and puts the data into a Queue that is shared with the main thread.
Main thread does some processing before it’s send to over network. The second worker process is used for all network communication.
Once in a while the serial input was missing characters, indicating the FEZ can’t keep up with the data that is received.
After optimizing some parts of the code all data is received completely.
Except in the situation when the network thread is excepting for some reason (internet gone, server offline, etc).
The reasons for the exception I cannot solve, so the exception will be thrown.
The data received at 9600 baud is a block between 20kB and 100kB, received without any flow control or resend mechanism. It’s far from ideal, but that’s the situation…
Using multiple threads I expected that the thread where the exception occurs will only suffer from the exception, but actually it has effect on all threads.
In the example below the “loop” times within the while loop are displayed for each thread.
When an exception occurs in W02, it will take about 500ms before it’s catched. And it will also increase the delay in the other two threads, sometimes with almost the same amount of time.
UsbToSerial (Prolific and FTDI) and UART are used to test if the serial thread could keep up, but on all methods received data is lost because it cannot keep up.
Questions
- How is an exception handled in the framework? Does it overrule the different threads until the exception is handled?
- Can the time for exception handling be reduced in some way? 500+ms is relative a lot of time.
- And maybe the most important is there another way to decrease the “loop” time of the W01 thread, so no incoming data will be dropped.
Program code
namespace MultithreadTest
private static int _threadSleepTime = 50;
Thread _w01 = new Thread(Worker01);
_w01.Start();
Thread _w02 = new Thread(Worker02);
_w02.Start();
DateTime d0 = DateTime.Now;
DateTime d1;
while(true)
d1 = DateTime.Now;
Debug.Print("M " + ((d1 - d0).Ticks / TimeSpan.TicksPerMillisecond).ToString());
d0 = d1;
Thread.Sleep(_threadSleepTime);
public static void Worker01()
DateTime d1;
while(true)
d1 = DateTime.Now;
Debug.Print("W01 " + ((d1 - d0).Ticks / TimeSpan.TicksPerMillisecond).ToString());
d0 = d1;
public static void Worker02()
DateTime d1;
DateTime dEx = DateTime.Now.AddMilliseconds(10000);
DateTime dExThrown = new DateTime(0);
DateTime dExCatched;
while(true)
try
d1 = DateTime.Now;
if (d1 > dEx)
dExThrown = DateTime.Now;
throw new Exception();
Debug.Print("W02 " + ((d1 - d0).Ticks / TimeSpan.TicksPerMillisecond).ToString());
d0 = d1;
catch
dExCatched = DateTime.Now;
Debug.Print("W02 EX " + ((dExCatched - dExThrown).Ticks / TimeSpan.TicksPerMillisecond).ToString());
Output shows something like
M 52
W02 52
W01 52
M 52
W02 52
W01 52
M 52
W02 52
W01 52
M 52
GC: 3msec 12684 bytes used, 51696 bytes available
Type 0F (STRING ): 108 bytes
Type 11 (CLASS ): 696 bytes
Type 12 (VALUETYPE ): 60 bytes
Type 13 (SZARRAY ): 108 bytes
Type 15 (FREEBLOCK ): 51696 bytes
Type 16 (CACHEDBLOCK ): 132 bytes
Type 17 (ASSEMBLY ): 7440 bytes
Type 18 (WEAKCLASS ): 48 bytes
Type 19 (REFLECTION ): 24 bytes
Type 1B (DELEGATE_HEAD ): 144 bytes
Type 1D (OBJECT_TO_EVENT ): 120 bytes
Type 1E (BINARY_BLOB_HEAD ): 156 bytes
Type 1F (THREAD ): 1152 bytes
Type 20 (SUBTHREAD ): 144 bytes
Type 21 (STACK_FRAME ): 1716 bytes
Type 27 (FINALIZER_HEAD ): 24 bytes
Type 31 (IO_PORT ): 36 bytes
Type 36 (APPDOMAIN_ASSEMBLY ): 504 bytes
W01 90
W02 52
M 92
W01 52
W02 95
M 52
W01 52
#### Exception System.Exception - 0x00000000 (4) ####
#### Message:
#### MultithreadTest.Program::Worker02 [IP: 0031] ####
W01 156
A first chance exception of type 'System.Exception' occurred in FEZ Domino Application.exe
W01 150
W01 149
W02 EX 455
W02 510
M 510
W01 52
W02 52
M 52
W01 52
#### Message:
W01 164
M 323
W01 153
M 149
W01 149
W02 EX 464
W02 519
M 52
W01 52
W02 52
M 52
W02 52
W01 52
M 52
#### Message:
M 204
W01 210
M 150
W01 150
M 150
W01 150
W02 EX 462
W02 516
M 52
W01 52
#### Message:
M 164
W01 163
M 150
W01 150
M 150
W01 150
W02 EX 463
W02 518
M 52
#### Message:
W01 161
M 161
W01 151
M 151
W01 148
M 148
W02 EX 460
W02 515
M 52
#### Message:
W01 204
M 163
W01 149
M 150
W01 150
M 150
W02 EX 463
W02 517
M 52
#### Message:
W01 157
M 157
W01 149
M 149
W01 150
M 150
W02 EX 457
W02 511
W01 52
M 52
#### Message:
M 155
W01 205
M 150
W01 150
M 150
W01 150
W02 EX 457
W02 511
M 52
W01 52
W02 52
