Gus, thank you for your reply. I’ve created an example below that throws the exception. When no file is written at all in Thread2 the exception shows
[quote] #### Exception System.IO.IOException - CLR_E_INVALID_DRIVER (6) ####
[/quote]
When one, two or more files are written, the exception shows
[quote] #### Exception System.IO.IOException - CLR_E_INVALID_DRIVER (5) ####
[/quote]
The code to init the network is never executed, cause the exception is thrown before. That is in contrast to what I wrote before.
using GHIElectronics.NETMF.Net.NetworkInformation;
using Microsoft.SPOT.IO;
using System.IO;
// References
// FEZDomino_GHIElectronics.NETMF.FEZ
// GHIElectronics.NETMF.IO
// GHIElectronics.NETMF.Net
// GHIElectronics.NETMF.System
// GHIElectronics.NETMF.W5100
// Microsoft.SPOT.Hardware
// Microsoft.SPOT.IO
// Microsoft.SPOT.Native
// mscorlib
// System.IO
// Using version 4.1.4.0
namespace NetworkAndStorageTest
static String _path = @ "\SD\Test";
// Init SD
InitSD();
// Write SD
WriteSD(DateTime.UtcNow.Ticks.ToString() + ".t1.txt");
// Read SD
ReadSD();
// Create new Thread2 object
Thread2 t = new Thread2();
// Set main thread to sleep 15s
Thread.Sleep(15000);
// Init Network
Debug.Print("Initing Network");
InitNetwork();
public static void InitSD()
PersistentStorage ps = new PersistentStorage("SD");
Debug.Print("Mounting SD");
ps.MountFileSystem();
Debug.Print("Mounted SD");
Thread.Sleep(1000);
public static void ReadSD()
String[] files = Directory.GetFiles(_path);
for (int i = 0; i < files.Length; i++)
FileInfo fi = new FileInfo(files[i]);
Debug.Print("Read " + fi.Name + " " + fi.LastWriteTimeUtc.ToString("yyyy-MM-dd HH:mm:ss") + " " + fi.Length);
//File.Delete(fi.FullName);
public static void WriteSD(String fileName)
if (!Directory.Exists(_path))
Directory.CreateDirectory(_path);
using (FileStream fs = new FileStream(_path + @ "\" + fileName, FileMode.OpenOrCreate))
byte[] buffer = System.Text.Encoding.UTF8.GetBytes(DateTime.UtcNow.ToString());
fs.Write(buffer, 0, buffer.Length);
fs.Close();
FileInfo fi = new FileInfo(_path + @ "\" + fileName);
Debug.Print("Written "+ fi.Name + " " + fi.LastWriteTimeUtc.ToString("yyyy-MM-dd HH:mm:ss") + " " + fi.Length);
public static void InitNetwork()
byte[] mac = {00, 00, 00, 10, 20, 30};
byte[] ip = {192, 168, 253, 189};
byte[] subnet = {255, 255, 255, 0};
byte[] gateway = {192, 168, 253, 254};
byte[] dns = {192, 168, 253, 254};
WIZnet_W5100.Enable(SPI.SPI_module.SPI1, (Cpu.Pin)FEZ_Pin.Digital.Di10, (Cpu.Pin)FEZ_Pin.Digital.Di9, true);
NetworkInterface.EnableStaticIP(ip, subnet, gateway, mac);
NetworkInterface.EnableStaticDns(dns);
// Writes a file to SD every 2 seconds
class Thread2
Thread _thread;
public Thread2()
_thread = new Thread(MainThread2);
Debug.Print("Starting thread 2");
_thread.Start();
Debug.Print("Started thread 2");
public void MainThread2()
Thread.Sleep(2000);
String fileName = DateTime.UtcNow.Ticks.ToString() + ".t2.txt";
Debug.Print("Writing " + fileName);
// System throws exception on next line
// Some times it will write no, one, two or three files before the exception occurs.
fs.Close();
Debug.Print("Written " + fi.Name + " " + fi.LastWriteTimeUtc.ToString("yyyy-MM-dd HH:mm:ss") + " " + fi.Length);
Thread.Sleep(2000);
