My hardware is:
- Fez Cobra 1.3
- Rs21 Module 1.1
The firmware is updated to “4.1.8.0” release.
This is my code:
GHIElectronics.NETMF.Net.WiFi.Enable(GHIElectronics.NETMF.Net.WiFi.HardwareModule.RS9110_N_11_21_1_Compatible,
Microsoft.SPOT.Hardware.SPI.SPI_module.SPI2,
(Cpu.Pin)2,
(Cpu.Pin)26,
(Cpu.Pin)3);
The system throw this exception:
Exception System.Exception - 0xffffffff (1)
#### Message:
#### GHIElectronics.NETMF.Net.RS21Driver::SetBootloadOption [IP: 0000] ####
#### GHIElectronics.NETMF.Net.WiFi::Enable [IP: 0051] ####
#### Modulus.Logic.Board::Initialize [IP: 004f] ####
#### Modulus.Program::myApp_Startup [IP: 0005] ####
#### Microsoft.SPOT.Application::OnStartup [IP: 000f] ####
#### Microsoft.SPOT.Application::StartupCallback [IP: 0007] ####
#### Microsoft.SPOT.Dispatcher::PushFrameImpl [IP: 004a] ####
#### Microsoft.SPOT.Dispatcher::PushFrame [IP: 001d] ####
#### Microsoft.SPOT.Dispatcher::Run [IP: 0006] ####
#### Microsoft.SPOT.Application::Run [IP: 0062] ####
#### Microsoft.SPOT.Application::Run [IP: 0005] ####
#### Modulus.Program::Main [IP: 0069] ####
GHI Wifi ErrorCode returned is “ErrorCode.HardwareCommunicationFailure”
Any suggestion ?
