using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using GHI.IO;
namespace CanSample2
public partial class Program
ControllerAreaNetwork CANBUS;
ControllerAreaNetwork CANBUS2;
byte runtime = 0;
timer.Tick +=<tab><tab>
timer.Start();
CANBUS = new ControllerAreaNetwork(ControllerAreaNetwork.Channel.One, ControllerAreaNetwork.Speed.Kbps1000);
CANBUS2 = new ControllerAreaNetwork(ControllerAreaNetwork.Channel.Two, ControllerAreaNetwork.Speed.Kbps1000);
CANBUS.ErrorReceived += can_ErrorReceived;
CANBUS.MessageAvailable += can_MessageAvailable;
CANBUS.Enabled = true;
CANBUS2.Enabled = true;
GT.Timer timer = new GT.Timer(5000);
timer.Tick += timer_Tick;
timer.Start();
//Thread.Sleep(-1);
Debug.Print("Sending Message");
ControllerAreaNetwork.Message message = new ControllerAreaNetwork.Message() { Data = new byte[] { 0, 0, 0, 0, 0, 0, 0, ++runtime }, Length = 8, IsRemoteTransmissionRequest = false, IsExtendedId = true };
CANBUS.SendMessage(message);
private static void can_MessageAvailable(ControllerAreaNetwork sender, ControllerAreaNetwork.MessageAvailableEventArgs e)
var received = sender.ReadMessage();
var data = string.Empty;
for (int i = 0; i < received.Length; i++)
data += "0x" + received.Data[i].ToString("x2") + " ";
//Debug.Print(" CAN Message ");
//Debug.Print("-----------------");
//Debug.Print(" ID: " + received.ArbitrationId.ToString());
//Debug.Print(" Time: " + received.TimeStamp.ToString());
//Debug.Print(" RTR: " + received.IsRemoteTransmissionRequest.ToString());
//Debug.Print(" EID: " + received.IsExtendedId.ToString());
//Debug.Print("Length: " + received.Length.ToString());
//Debug.Print(" Data: " + data);
//Debug.Print("");
sender.SendMessage(new ControllerAreaNetwork.Message() { Data = BitConverter.GetBytes(received.ArbitrationId), ArbitrationId = 0x12345678, Length = 8, IsRemoteTransmissionRequest = false, IsExtendedId = true });
private static void can_ErrorReceived(ControllerAreaNetwork sender, ControllerAreaNetwork.ErrorReceivedEventArgs e)
Debug.Print("Error on CAN: " + e.Error.ToString());
@ Dat - It appears the issue is with GHI Electronics NETMF SDK 2015 R1 Pre-Release 4
However the issue does not occur with NETMF and Gadgeteer Package 2014 R5
Sorry, we can not confirm :D, because we just tested it and working well.
@ ialastairhunter
I am curious because your code looks like not correct. How it works on 2014R1?
Anyway, here is your code with some correction from us, tested on 4.3.7.10.
using GHI.IO;
namespace CAN43_Gadgeeter
byte runtime = 0;
timer.Start();
CANBUS2.MessageAvailable += CANBUS2_MessageAvailable;
timer.Start();
ControllerAreaNetwork.Message[] inBuffer = new ControllerAreaNetwork.Message[1024];
void CANBUS2_MessageAvailable(ControllerAreaNetwork sender, ControllerAreaNetwork.MessageAvailableEventArgs e)
var msg = sender.ReadMessage();
Debug.Print("Can 2: Received = " + msg.ArbitrationId
+ " " + msg.Data[0]
+ " " + msg.Data[1]
+ " " + msg.Data[2]
+ " " + msg.Data[3]
+ " " + msg.Data[4]
+ " " + msg.Data[5]
+ " " + msg.Data[6]
+ " " + msg.Data[7]
+ " " + msg.IsExtendedId
+ " " + msg.IsRemoteTransmissionRequest
+ " " + msg.TimeStamp
sender.SendMessage(new ControllerAreaNetwork.Message() { Data = new byte[] { 2, 2, 2, 2, 2, 2, 2, ++runtime }, ArbitrationId = 0x87654321, Length = 8, IsRemoteTransmissionRequest = false, IsExtendedId = true });
ControllerAreaNetwork.Message message = new ControllerAreaNetwork.Message() { Data = new byte[] { 1, 1, 1, 1, 1, 1, 1, ++runtime }, ArbitrationId = 0x12345678, Length = 8, IsRemoteTransmissionRequest = false, IsExtendedId = true };
private void can_MessageAvailable(ControllerAreaNetwork sender, ControllerAreaNetwork.MessageAvailableEventArgs e)
Debug.Print("Can 1: Received = " + msg.ArbitrationId
+ " " + msg.Data[0]
+ " " + msg.Data[1]
+ " " + msg.Data[2]
+ " " + msg.Data[3]
+ " " + msg.Data[4]
+ " " + msg.Data[5]
+ " " + msg.Data[6]
+ " " + msg.Data[7]
I have the same issue with the raptor, but it works with G120 on CobraII.
I try on several Raptor but the issue remains the same.
Sometimes I got the exception, and sometimes not, but SendMessage method returns “false” and no message on the bus can be seen.
I use this code
using GHI.IO;
public class Program : Gadgeteer.Program
public static Program ProgramInstance;
private static int count = 0;
timer.Start();
CANBUS = new ControllerAreaNetwork(ControllerAreaNetwork.Channel.One, ControllerAreaNetwork.Speed.Kbps250);
GT.Timer timer = new GT.Timer(2000);
timer.Start();
ControllerAreaNetwork.Message message = new ControllerAreaNetwork.Message() { Data = new byte[] { 0, 0, 0, 0, 0, 0, 0, (byte)(count%255) }, Length = 8, IsRemoteTransmissionRequest = false, IsExtendedId = true };
try
if(CANBUS.SendMessage(message))
Debug.Print(String.Concat("Msg#", ++count, ": ok"));
Debug.Print(String.Concat("Msg#", ++count, ": failed"));
catch
Debug.Print("Message received");
public static void Main(string[] args)
Program.Mainboard = new GHIElectronics.Gadgeteer.FEZRaptor();
ProgramInstance = new Program();
ProgramInstance.ProgramStarted();
// Starts Dispatcher
ProgramInstance.Run();
I copied exactly your code and run on our side, it is working fine.
Only way to get your exception is, make a bad connection.
So I guess you should check your connection. If the connection was your problem, easy to see that once it worked, it always work, once it fails, it will be always failed, of course, without changing/touching anything on its connection.
What do you mean when you talk about bad connection ? is nothing connected, only the 120 ohm terminator is a bad connection ?
For example, if i run my program G120 without connecting anything to CAN bus, it perfectly works. But if I do exactly the same with G400, it doesn’t work.
@ Gus - I mean “it works” when there is no exception and the SendMessage method returns true.
The program “works” with G120, but not G400 with SDK 2015. And it works with G120 and G400 with SDK 2014.
I also tried to add nodes connected to the CAN bus and the results are the same.
Could you explain in which situation the CAN bus could raise an exception ? maybe it could help to explain why it doesn’t work. In my opinion, maybe i’m wrong, if the module is not connected, there is no reason to raise an exception…
One of the many tests I made: I just run the program on a FEZ Raptor with no attached module. Is it regular to get exception when you try to send messages in this configuration ? Same test with FEZ Cobra 2 Eco : no exception.
