hi,
I want to use the SerialPort.DataReceived Event so i take the code of the last example in the msdn library site :
I add in the reference part of the project mscorlib, system, Microsoft.SPOT.Native, Microsoft.SPOT.hardware.serialports, system.io.
And I’ve a lot of errors on SerialDataReceivedEventHandler, Console, Parity, Stopbits, ReadExisting …
So i don’t understand why i could have so many errors with the last code example …
And is there a simple way to discover which reference i’ve to add to to project to make working the “console class” ? In the documentation is write to add “mscorlib in system” but it doesn’t work.
I’m using visual c# 2010 and framework 4.1. My project is a micro framework console application type.
Which error i’ve done ?
thanks for your help
