Ethernet
I am trying to get ENC28 1.1 working.
It blows up when I do the listenSocket.Bind(ep);
I also cannot get an IP address, but also tried to bind statically.
I tested the cable on another computer and got an IP address fine.
Stack Trace
Found debugger!
Create TS.
Loading start at a0e00000, end a0e1383c
Assembly: mscorlib (4.2.0.0) Assembly: Microsoft.SPOT.Native (4.2.0.0) Assembly: Microsoft.SPOT.Security.PKCS11 (4.2
.0.0) Assembly: System.Security (4.2.0.0) Loading Deployment Assemblies.
Attaching deployed file.
Assembly: Microsoft.SPOT.IO (4.2.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0) Attaching deployed file.
Assembly: Gadgeteer (2.42.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Graphics (4.2.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.TinyCore (4.2.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Hardware (4.2.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net.Security (4.2.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.Ethernet_ENC28 (1.1.3.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Touch (4.2.0.0) Attaching deployed file.
Assembly: System.Http (4.2.0.0) Attaching deployed file.
Assembly: System (4.2.0.0) Attaching deployed file.
Assembly: System.Net.Security (4.2.0.0) Attaching deployed file.
Assembly: GHI.Premium.Net (4.2.7.0) Attaching deployed file.
Assembly: AirStream (1.0.0.0) Attaching deployed file.
Assembly: System.IO (4.2.0.0) Attaching deployed file.
Assembly: Gadgeteer.SPI (2.42.0.0) Attaching deployed file.
Assembly: GHI.Premium.IO (4.2.7.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.2.0.0) Attaching deployed file.
Assembly: GHI.Premium.Hardware (4.2.7.0) Attaching deployed file.
Assembly: GHI.Premium.System (4.2.7.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZSpider (1.1.1.0) Resolving.
GC: 1msec 37296 bytes used, 7302372 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 7302372 bytes
Type 17 (ASSEMBLY ): 33156 bytes
Type 1E (BINARY_BLOB_HEAD ): 4044 bytes
GC: performing heap compaction…
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Security.PKCS11.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Graphics.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.TinyCore.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘G:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.2\le\Gadgeteer.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘G:\Program Files (x86)\GHI Electronics\GHI Premium NETMF v4.2 SDK\Assemblies\le\GHI.Premium.Net.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘G:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.2\le\Gadgeteer.SPI.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘G:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\Ethernet_ENC28\NETMF 4.2\le\GTM.GHIElectronics.Ethernet_ENC28.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Touch.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Net.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Http.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘G:\Program Files (x86)\GHI Electronics\GHI Premium NETMF v4.2 SDK\Assemblies\le\GHI.Premium.System.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘G:\Program Files (x86)\GHI Electronics\GHI Premium NETMF v4.2 SDK\Assemblies\le\GHI.Premium.IO.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘G:\Program Files (x86)\GHI Electronics\GHI Premium NETMF v4.2 SDK\Assemblies\le\GHI.Premium.Hardware.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘G:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Mainboards\FEZSpider\NETMF 4.2\le\GHIElectronics.Gadgeteer.FEZSpider.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘G:\Users\mweel\documents\visual studio 2010\Projects\AirStream\AirStream\bin\Debug\le\AirStream.exe’, Symbols loaded.
Using mainboard GHI Electronics FEZSpider version 1.0
Step into: Stepping over non-user code ‘Microsoft.SPOT.Net.NetworkInformation.NetworkInterface.GetAllNetworkInterfaces’
WARN: Total initialization time exceeds 10 seconds.
: ProgramStarted is blocking execution, which means events and timers will not run properly.
: Make sure not to use blocking code such as while(true) - use a GT.Timer instead.
WARN: Total initialization time exceeds 20 seconds.
#### Exception System.Net.Sockets.SocketException - CLR_E_FAIL (1) ####
#### Message:
#### Microsoft.SPOT.Net.SocketNative::bind [IP: 0000] ####
#### System.Net.Sockets.Socket::Bind [IP: 0016] ####
#### AirStream.Program::ProgramStarted [IP: 0051] ####
#### AirStream.Program::Main [IP: 0015] ####
#### SocketException ErrorCode = 10022
A first chance exception of type ‘System.Net.Sockets.SocketException’ occurred in Microsoft.SPOT.Net.dll
An unhandled exception of type ‘System.Net.Sockets.SocketException’ occurred in Microsoft.SPOT.Net.dll
Uncaught exception
Any help would be much appreciated.
Thank you,
Marty
 // First, make sure we actually have a network interface to work with!
            if (Microsoft.SPOT.Net.NetworkInformation.NetworkInterface.GetAllNetworkInterfaces().Length < 1)
                Debug.Print("No Active network interfaces. Bombing out.");
                Thread.CurrentThread.Abort();
            // OK, retrieve the network interface
            Microsoft.SPOT.Net.NetworkInformation.NetworkInterface NI = Microsoft.SPOT.Net.NetworkInformation.NetworkInterface.GetAllNetworkInterfaces()[0];
             //If DHCP is not enabled, then enable it and get an IP address, else renew the lease. Most iof us have a DHCP server
             //on a network, even at home (in the form of an internet modem or wifi router). If you want to use a static IP
             //then comment out the following code in the "DHCP" region and uncomment the code in the "fixed IP" region.
            #region DHCP Code
            //if (NI.IsDhcpEnabled == false)
            //    Debug.Print("Enabling DHCP.");
            //    NI.EnableDhcp();
            //    Debug.Print("DCHP - IP Address = " + NI.IPAddress + " ... Net Mask = " + NI.SubnetMask + " ... Gateway = " + NI.GatewayAddress);
            //else
            //    Debug.Print("Renewing DHCP lease.");
            //    NI.RenewDhcpLease();
            #endregion
            //#region Static IP code
            //// Uncomment the following line if you want to use a static IP address, and comment out the DHCP code region above
                NI.EnableStaticIP("10.0.1.56", "255.255.255.0", "10.0.1.1");
            //#endregion
            // Create the socket
            Socket listenSocket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
            // Bind the listening socket to the port
            IPAddress hostIP = IPAddress.Parse(NI.IPAddress);
            IPEndPoint ep = new IPEndPoint(hostIP, 80);
            // Start listening
            listenSocket.Listen(1);
            // Main thread loop
                try
                    Debug.Print("listening...");
                    Socket newSock = listenSocket.Accept();
                    Debug.Print("Accepted a connection from " + newSock.RemoteEndPoint.ToString());
                    byte[] messageBytes = Encoding.UTF8.GetBytes("Hello, browser! I think the time is " + DateTime.Now.ToString());
                    newSock.Send(messageBytes);
                    newSock.Close();
                catch (Exception e)
                    Debug.Print(e.Message);
Using code tags will make your post more readable. This can be done in two ways:[ol]
Click the “101010” icon and paste your code between the
 tags or...
Select the code within your post and click the "101010" icon.[/ol]
(Generated by QuickReply)
Of course it will “blow up” when you bind to a socket, if you can’t get an IP address !
You need to tell us what device and what firmware version; there’s lots of issues with the 4.2 firmware, but at least knowing what device we’re talking about will help
I have not done anything with an ENC28 yet. Does a MAC address need to be saved in the network configuration, or at execution time?
@ Brett I tried to bind one statically also. The device is a ENC28 1.1. Not sure where to find the firmware information for you, or for what?
This is the main board:
http://www.ghielectronics.com/catalog/product/297
@ Mike I assume that question is for the group not me. I did nothing to set a MAC address on ethernet device.
Thanks fellas.
Marty
Usually the spider board uses a J11D for Ethernet. The code you are using is for an OSHW device. The Spider is a premium device, which has a different initialization procedure.
This thread has sample code you could modify for ENC28. http://www.tinyclr.com/forum/topic?id=10446&page=2
You want to use the EthernetENC28J60 class.
I also have the J11D, are you saying my code should work OK with that?
Thanks,
Marty
Andre,
That did it.
Seems like there are a lot of ways to handle networking differently depending on the hardware.
Does anyone have any documentation on how that works and what the different classes might be?
Thanks,
Marty
@ andre.m
Hi there. I’m Wondering do I have the right Ethernet_J11D library (mine is showing as v4.0.30319 in VS) ? I can match your coded solution up until.
ethernet_J11D.UseStaticIP(ip, mask, gw);
but I only have the following method call which comes close to this code (my Ethernet_J11D module is called ethernet)
ethernet.Interface.NetworkInterface.EnableStaticIP(ip,mask,gw);
and when the Interface_NetworkAddressChanged(object sender, EventArgs e) event fires I get a 0.0.0.0 ip address.
I am using .netmf 4.2 with appropriate updated firmware on a FEZ spider (4.2.7.0).
I have managed to assign a static address to the FEZ spider using the .netmf low level reference
NetworkInterface networkInterface = NetworkInterface.GetAllNetworkInterfaces()[0];
However I cannot get DHCP to work with any method with a Ethernet_J11D module. Is it possible to get DHCP running on a FEZ spider?
@ andre.m.
Apologies.
Correction the ip address is set when the event fires. But I’m still wondering about the difference in methods and if DHCP is possible?
Thank you.
looks like i’m answering my own posts here :slight_smile: . I Have got DHCP to configure with this call
ethernet.Interface.NetworkInterface.EnableDhcp();
and ip, sub mask and Gateway are right.
Now just wondering about the difference in the method calls before I go deeper into writing code against network functionality. There seems to be a few different versions of the Ethernet_J11D dll floating around inheriting from different classes?
As part of the 4.2 Premium SDK, the process for initializing the J11D module changed. This was done to allow multiple IP hardware interfaces to
exist on a device, for example hardwire and Wifi. At the present time, only one IP device can be active, but they can be switch
during the running of a program.
@ Mike
Thanks for that Mike.
So just to clarify. Is ethernet.UseDHCP() a .netmf 4.1 method and the new equivalent in 4.2 is ethernet.Interface.NetworkInterface.EnableDhcp();?
Thanks again.
The SDK comes out this week adds the gadgeteer Ethernet wrappers back, just like 4.1
I’ve noticed that nobody sets the mac-address from code. Does this mean that you all expect it to be present from the config.hex and mfdeploy tool?
Ok, but when the device (for example fez-spider) is being updated (IFU or MFDeploy) will the mac-address overwritten?
Since an erase of the device is done, during firmware installation, I would assume that the MAC address is erased and replaced with the default address.
I often set the MAC address in the code.
I also set the MAC address in code, it is stored on a sd card. But lately I read a couple of older threads on the forum about the dhcp issues again and I noticed that I never saw setting the mac address in the provided sample code. The MAC address is essential for a DHCP server, so I was thinking if that could be a source of problems?
Here is a network class that works for me.
using System.Text;
using GHI.Premium.Net;
namespace NtpTesting.Network_J11D
    class Network
        public event EventHandler CableChanged;
        public event EventHandler NetworkChanged;
        public bool DHCPEnabled { get; set; }
        public string Ip { get; set; }
        public string NetMask { get; set; }
        public string Gateway { get; set; }
        public string[] DNS { get; set; }
        public bool NetworkUp { get; set; }
        public Gadgeteer.Modules.GHIElectronics.Ethernet_J11D _ether;
        /// <summary>
        /// Start Ethernet using DHCP
        /// </summary>
        /// <param name="ethernet_J11D"></param>
        public Network(Gadgeteer.Modules.GHIElectronics.Ethernet_J11D ethernet_J11D)
            this.DHCPEnabled = true;
            _ether = ethernet_J11D;
            startnet();
        /// <summary>
        /// Start Ethernet using static IP
        /// </summary>
        /// <param name="ip">"10.2.1.1"</param>
        /// <param name="netmask">"255.255.255.0"</param>
        /// <param name="gateway">"10.2.1.254"</param>
        /// <param name="dns">new string[] {"10.2.1.67","10.2.1.68"}</param>
        public Network(Gadgeteer.Modules.GHIElectronics.Ethernet_J11D ethernet_J11D, string ip, string netmask, string gateway, string[] dns)
            this.Ip = ip;
            this.NetMask = netmask;
            this.Gateway = gateway;
            this.DNS = dns;
            this.DHCPEnabled = false;
            startnet();
        void startnet()
            //byte[] newMac = new byte[] { 0x00, 0x21, 0x03, 0x80, 0x53, 0x7C };
            _ether.Interface.Open();
            NetworkInterfaceExtension.AssignNetworkingStackTo(_ether.Interface);
            //(NetworkInterface.GetAllNetworkInterfaces())[0].PhysicalAddress = newMac;
            _ether.NetworkUp += OnNetworkUp;
            _ether.NetworkDown += OnNetworkDown;
            _ether.Interface.CableConnectivityChanged +=
                new EthernetBuiltIn.CableConnectivityChangedEventHandler(Interface_CableConnectivityChanged);
            if (_ether.Interface.IsCableConnected)
                SetupEthernet();
        void Interface_CableConnectivityChanged(object sender, EthernetBuiltIn.CableConnectivityEventArgs e)
            // Invoke the Changed event; called whenever cable connectivity changes:
            if (CableChanged != null)
                CableChanged(this, e);
        void OnNetworkDown(GTM.Module.NetworkModule sender, GTM.Module.NetworkModule.NetworkState state)
            MyEventArgs e = new MyEventArgs();
            e.IsUp = state == GTM.Module.NetworkModule.NetworkState.Up;
            this.NetworkUp = e.IsUp;
            if (NetworkChanged != null)
                NetworkChanged(sender, e);
        void OnNetworkUp(GTM.Module.NetworkModule sender, GTM.Module.NetworkModule.NetworkState state)
        public void SetupEthernet()
            if (this.DHCPEnabled)
                _ether.UseDHCP();
                _ether.UseStaticIP(
                    this.Ip, //"10.2.1.10",
                    this.NetMask, //"255.255.255.0",
                    this.Gateway, //"10.2.1.63",
                    this.DNS);
        public string ListNetworkInterfaces()
            StringBuilder rstring = new StringBuilder();
            var settings = _ether.NetworkSettings;
            rstring.Append("------------------------------------------------\r");
            rstring.Append("MAC: " + ByteExtensions.ToHexString(settings.PhysicalAddress, "-") + "\r");
            rstring.Append("IP Address:   " + settings.IPAddress + "\r");
            rstring.Append("DHCP Enabled: " + settings.IsDhcpEnabled + "\r");
            rstring.Append("Subnet Mask:  " + settings.SubnetMask + "\r");
            rstring.Append("Gateway:      " + settings.GatewayAddress + "\r");
            for (int i = 0; i < settings.DnsAddresses.Length; i++)
                rstring.Append("DNS:          " + settings.DnsAddresses[i] + "\r");
            rstring.Append("------------------------------------------------" + "\r");
            return rstring.ToString();
    public class MyEventArgs : EventArgs
        public bool IsUp { get; set; }
A unique MAC address is essential for all devices on the same network, regardless of DHCP!
