Given that the G120E with it’s ethernet against a Wiznet 5500, which requires less compute cycles in terms of the TCP/IP stuff.
The way I see it is that the G120’s main processor has to handle the tcp/ip window size, ping requests etc all from the main cpu. The question is: Do those TCP/IP functions run off the main CPU when using the G120E’s Ethernet interface?
