I am having some trouble with a HttpWebRequest. I am using a PANDA II and the code to initialise Ethernet and send the data to server is detailed below:
the “get” request is ok with a PC.
where is the documentations of HttpWebRequest and socket tcp cliente etc…?
using System.IO;
using System.Text;
using GHIElectronics.NETMF.Net.NetworkInformation;
/// This program demonstrates how to use the .NET Micro Framework HTTP classes
/// to create a simple HTTP client that retrieves pages from several different
/// websites, including secure sites.
namespace HttpClientSample
public static class MyHttpClient
/// Retrieves a page from a Web server, using a simple GET request.
byte[] mac = { 0x00, 0x26, 0x1C, 0x7B, 0x29, 0xE8 };
WIZnet_W5100.Enable(SPI.SPI_module.SPI1, (Cpu.Pin)FEZ_Pin.Digital.Di10, (Cpu.Pin)FEZ_Pin.Digital.Di9, true); // WIZnet interface on FEZ Connect
Dhcp.EnableDhcp(mac);
Debug.Print("Network settings:");
Debug.Print("IP Address: " + new IPAddress(NetworkInterface.IPAddress).ToString());
Debug.Print("Subnet Mask: " + new IPAddress(NetworkInterface.SubnetMask).ToString());
Debug.Print("Default Getway: " + new
IPAddress(NetworkInterface.GatewayAddress).ToString());
Debug.Print("DNS Server: " + new IPAddress(NetworkInterface.DnsServer).ToString());
// Print the HTTP data from each of the following pages.
PrintHttpData("GET /dataxesNet.asr/Comm?y=109627&m=AAAAAAAA&d=gQH3sAEP1BnB4jQHVbU =HTTP/1.1\r\nHost:tgt1.dataxework.net\r\n\r\n.");
/// <summary>
/// Prints the HTTP Web page from the given URL and status data while
/// receiving the page.
/// </summary>
/// <param name="url">The URL of the page to print.</param>
public static void PrintHttpData(string url)
// Create an HTTP Web request.
HttpWebRequest request =
HttpWebRequest.Create(url) as HttpWebRequest;
// Set request.KeepAlive to use a persistent connection.
request.KeepAlive = true;
// Get a response from the server.
WebResponse resp = null;
try
resp = request.GetResponse();
catch (Exception e)
Debug.Print("Exception in HttpWebRequest.GetResponse(): " +
e.ToString());
// Get the network response stream to read the page data.
if (resp != null)
Stream respStream = resp.GetResponseStream();
string page = null;
byte[] byteData = new byte[2048];
char[] charData = new char[2048];
int bytesRead = 0;
Decoder UTF8decoder = System.Text.Encoding.UTF8.GetDecoder();
int totalBytes = 0;
// allow 5 seconds for reading the stream
respStream.ReadTimeout = 5000;
// If we know the content length, read exactly that amount of
// data; otherwise, read until there is nothing left to read.
if (resp.ContentLength != -1)
for (int dataRem = (int)resp.ContentLength; dataRem > 0; )
Thread.Sleep(500);
bytesRead =
respStream.Read(byteData, 0, byteData.Length);
if (bytesRead == 0)
Debug.Print("Error: Received " +
(resp.ContentLength - dataRem) + " Out of " +
resp.ContentLength);
break;
dataRem -= bytesRead;
// Convert from bytes to chars, and add to the page
// string.
int byteUsed, charUsed;
bool completed = false;
totalBytes += bytesRead;
UTF8decoder.Convert(byteData, 0, bytesRead, charData, 0,
bytesRead, true, out byteUsed, out charUsed,
out completed);
page = new String(charData, 0, charUsed);
// Display the page results.
Debug.Print(page);
page = new String(
System.Text.Encoding.UTF8.GetChars(byteData));
// Read until the end of the data is reached.
// If the Read method times out, it throws an exception,
// which is expected for Keep-Alive streams because the
// connection isn't terminated.
try
Thread.Sleep(500);
bytesRead =
catch (Exception)
bytesRead = 0;
// Zero bytes indicates the connection has been closed
// by the server.
if (bytesRead == 0)
break;
out completed);
Debug.Print(page);
// Close the response stream. For Keep-Alive streams, the
// stream will remain open and will be pushed into the unused
// stream list.
resp.Close();
error
Network settings:
IP Address: 192.168.1.100
Subnet Mask: 255.255.255.0
Default Getway: 192.168.1.1
DNS Server: 24.201.245.77
#### Exception System.ArgumentException - 0x00000000 (1) ####
#### Message:
#### GHIElectronics.NETMF.Net.Uri::ParseUriString [IP: 00a7] ####
#### GHIElectronics.NETMF.Net.Uri::ConstructAbsoluteUri [IP: 0005] ####
#### GHIElectronics.NETMF.Net.Uri::.ctor [IP: 0016] ####
#### GHIElectronics.NETMF.Net.WebRequest::Create [IP: 0004] ####
#### HttpClientSample.MyHttpClient::PrintHttpData [IP: 0005] ####
#### HttpClientSample.MyHttpClient::Main [IP: 0077] ####
Excepción del tipo 'System.ArgumentException' en GHIElectronics.NETMF.W5100.Http.dll
Excepción no controlada del tipo 'System.ArgumentException' en GHIElectronics.NETMF.W5100.Http.dll
Uncaught exception
El subproceso '<Sin nombre>' (0x1) terminó con código 0 (0x0).
thanks!
