I’ve been playing around with my hydra mainboard and I want to finally get started with the network connection. I have the Ethernet ENC28 Module and I’ve seen on the documentation page (https://www.ghielectronics.com/docs/68/ethernet-enc28-module) that one should not connect the module in the surface designer. Everything fine so far.
But is there a tutorial out there or any help on how to get started. I want to connect my hydra to my home network and communicate with my notebook on the same network etc. That as a starting point.
But I’ve managed to do it now. After several tries it finally works However, I have no idea why it did not work before.
Anyway, the Gadget now has an IP address.
My next step would be to enable communication with my notebook on the same network and/or calling rest webservices. My final goal will be to use Rest calls (POST/GET) in order to send data to a rest service and receive data from a rest service. For the first step I have implemented a small application with a Rest Api including a small webserver on my notebook. I would like to send data to that application from my gadget (and receive data on my gadget with GET calls).
I have found multiple projects on the web that use network communication but as you guys have more experience maybe you can recommend a really good tutorial or anything like that that is good as a starting point?
Thanks a lot for the really great support. Questions are always answered really fast!
