Hello
I have a raptor main board with Ethernet ENC28 and sd card.
simply, I want to send a large size file from SD to my webserver. I devide my file to 500Kb byte arrays and send each of them to my webserver. then I append received byte arrays to a file.
so far, I used netmf 4.2 and following code was working correctly :
FileStream fileStream = new FileStream(FilePath, FileMode.Open, FileAccess.Read);
long TotalPackages = fileStream.Length / 500000;
if (TotalPackages > 0)
try
for (int j = 0; j < TotalPackages; j++)
byte[] FileData = new byte[PackageLength];
fileStream.Read(FileData, 0, PackageLength);
WebRequest request = WebRequest.Create("http://172.16.50.43:42124/API.aspx?Type=File");
request.Method = "POST";
request.ContentType = "multipart/form-data";
request.ContentLength = FileData.Length;
request.Headers.Add("FileName", FileName);
Stream dataStream = request.GetRequestStream();
dataStream.Write(FileData, 0, FileData.Length);
dataStream.Close();
WebResponse response = request.GetResponse();
result = ((HttpWebResponse)response).Headers["res"];
if (result == null)
return false;
// Get the stream containing content returned by the server.
dataStream = response.GetResponseStream();
StreamReader reader = new StreamReader(dataStream);
string responseFromServer = reader.ReadToEnd();
reader.Close();
dataStream.Close();
response.Close();
if (result == "true")
return true;
catch (Exception e)
return false;
but now, I’m using netmf 4.3 and when program reachs to this line for first time :
I receive error about socket exception…
Can everybody help me?
thanks
