Hey I’m just running a test here, on Microsoft emulator. its net gadgeteer.
I got an error when it was running. I believe I installed everything correctly. Will this problem go away once I get a real board or is it necessary to fix
@ MRTFEREN - One restriction is that you can use only plain NETMF code with the emulator.
@ MRTFEREN - The problem is that you are trying to use GHI libraries on the emulator. Those libraries are only available on physical GHI boards.
Ahh, I understand. I just tried coding basic stuff with the tunes module and the led strip in gadgeteer and it is already 100x easier than an arduino, just because it has auto complete(I rely on that somuch) and I don’t need to worry about pins!
Spread the word to everyone you know! ;D
