I keep bumping into the restriction of 65K per assembly. I have successfully transfered sum code to other assemblies/DLLs. The latest go around resulted in and error. Here is the output:
Found debugger!
Create TS.
Attaching deployed file.
Assembly: Vista_TinyCLR (1.0.0.0) Attaching deployed file.
Assembly: mscorlib (1.0.0.0) Attaching deployed file.
Assembly: Vista_DataDefs (1.0.0.0) Attaching deployed file.
Assembly: Vista_Components (1.0.0.0) Attaching deployed file.
Assembly: GHIElectronics.TinyCLR.IO (1.0.0.0) Attaching deployed file.
Assembly: GHIElectronics.TinyCLR.Drawing (1.0.1.0)
Error: the reference GHIElectronics.TinyCLR.Drawing cannot be used with this version of the firmware.
Firmware checksum 0xF2B1785E does not match the assembly checksum 0xC8AB3CAB.
Resolving.
Assembly: Vista_TinyCLR (1.0.0.0) needs assembly âGHIElectronics.TinyCLR.Devices.I2câ (1.0.0.0)
Assembly: Vista_TinyCLR (1.0.0.0) needs assembly âGHIElectronics.TinyCLR.Devices.Gpioâ (1.0.0.0)
Assembly: Vista_TinyCLR (1.0.0.0) needs assembly âGHIElectronics.TinyCLR.Devices.Canâ (1.0.0.0)
Assembly: Vista_TinyCLR (1.0.0.0) needs assembly âGHIElectronics.TinyCLR.Drawingâ (1.0.1.0)
Assembly: Vista_TinyCLR (1.0.0.0) needs assembly âVista_Componentsâ (1.0.0.0)
Assembly: Vista_TinyCLR (1.0.0.0) needs assembly âVista_Keyboardâ (1.0.0.0)
Assembly: Vista_TinyCLR (1.0.0.0) needs assembly âVista_DataDefsâ (1.0.0.0)
Assembly: Vista_TinyCLR (1.0.0.0) needs assembly âGHIElectronics.TinyCLR.Devices.Displayâ (1.0.0.0)
Assembly: Vista_TinyCLR (1.0.0.0) needs assembly âVista_GlobalSettingsâ (1.0.0.0)
Assembly: Vista_TinyCLR (1.0.0.0) needs assembly âGHIElectronics.TinyCLR.Devices.Uartâ (1.0.0.0)
Assembly: Vista_TinyCLR (1.0.0.0) needs assembly âVista_Statâ (1.0.0.0)
Assembly: Vista_TinyCLR (1.0.0.0) needs assembly âVista_Helpersâ (1.0.0.0)
Assembly: Vista_TinyCLR (1.0.0.0) needs assembly âGHIElectronics.TinyCLR.Nativeâ (1.0.0.0)
Assembly: Vista_TinyCLR (1.0.0.0) needs assembly âGHIElectronics.TinyCLR.Pins.UCMâ (1.0.0.0)
Assembly: Vista_DataDefs (1.0.0.0) needs assembly âGHIElectronics.TinyCLR.Drawingâ (1.0.1.0)
Assembly: Vista_DataDefs (1.0.0.0) needs assembly âGHIElectronics.TinyCLR.Devices.Storageâ (1.0.0.0)
Assembly: Vista_DataDefs (1.0.0.0) needs assembly âVista_Statâ (1.0.0.0)
Assembly: Vista_DataDefs (1.0.0.0) needs assembly âVista_Helpersâ (1.0.0.0)
Assembly: Vista_Components (1.0.0.0) needs assembly âGHIElectronics.TinyCLR.Drawingâ (1.0.1.0)
Assembly: Vista_Components (1.0.0.0) needs assembly âVista_Statâ (1.0.0.0)
Assembly: Vista_Components (1.0.0.0) needs assembly âVista_DataDefsâ (1.0.0.0)
Error: a3000000
Waiting for debug commandsâŚ
The program â[136] TinyCLR application: Managedâ has exited with code 0 (0x0).
I have used TinyClr Config to ensure the correct firmware. (UC5550 V1.0.0)
What do I do now ???
