Hello all,
I need your help I am on a project where I use G120HDR card. I have since the beginning developped a lot of code that works fine , except I have a problem. During the course of my program all goes well until a certain time window where the output it appears that:
GC: 27msec 987912 bytes used, 6351756 bytes available
Type 0F (STRING ): 214284 bytes
Type 11 (CLASS ): 146844 bytes
Type 12 (VALUETYPE ): 26244 bytes
Type 13 (SZARRAY ): 78084 bytes
Type 03 (U1 ): 480 bytes
Type 04 (CHAR ): 480 bytes
Type 06 (U2 ): 108 bytes
Type 07 (I4 ): 468 bytes
Type 0F (STRING ): 144 bytes
Type 11 (CLASS ): 76404 bytes
Type 15 (FREEBLOCK ): 6351756 bytes
Type 16 (CACHEDBLOCK ): 48 bytes
Type 17 (ASSEMBLY ): 31716 bytes
Type 18 (WEAKCLASS ): 96 bytes
Type 19 (REFLECTION ): 180 bytes
Type 1B (DELEGATE_HEAD ): 756 bytes
Type 1D (OBJECT_TO_EVENT ): 336 bytes
Type 1E (BINARY_BLOB_HEAD ): 476784 bytes
Type 1F (THREAD ): 2688 bytes
Type 20 (SUBTHREAD ): 288 bytes
Type 21 (STACK_FRAME ): 5100 bytes
Type 23 (LOCK_HEAD ): 60 bytes
Type 24 (LOCK_OWNER_HEAD ): 24 bytes
Type 27 (FINALIZER_HEAD ): 360 bytes
Type 28 (MEMORY_STREAM_HEAD ): 36 bytes
Type 29 (MEMORY_STREAM_DATA ): 396 bytes
Type 31 (IO_PORT ): 216 bytes
Type 36 (APPDOMAIN_ASSEMBLY ): 3300 bytes
From this moment I am unable to use the interrupt button I use to read the SD card
Thank you in advance for your help.
