ERROR: Can't copy file
I recently moved from my old XP system to Windows 7. I installed Visual c## and the other modules. When I try to compile a program I get:
Error 3 Could not copy the file “C:\Users\Tom\Documents\Visual Studio 2010\Projects\MessageBoard\MessageBoard\bin\Debug\LE\GHIElectronics.NETMF.Hardware.pe” because it was not found.
There are hardware.pe files in other directories. What did I miss?
I’d start by trying a reinstall of the latest GHI SDK.
I did download and install the latest. I copied the source files to temporary files and created a new project. That worked. When I looked in the directory for the hardware.pe file it had a mod date of February 16, 2012. It must be copied from one of the install directories, and since everything is in different directories on Windows 7, I guess I need to make new project files for everything.
Yes, definitely. If you use default folder structures then they are definitely different.
