hello
I want to read a frame (string []) on the serial port .
is there a method or code share equivalante to the method of SerialPort.ReadLine (string []) on Net Micro Frame ?
sorry,
hello
I want to read trame of message type: string [] on the serial port .
is there a method or code share equivalante to the method of SerialPort.ReadLine (string []) on .Net Frame (on the PC)?
THX
@ riad1986 - This is untested but should provide assistance. The code will only work for bytes in the lower ASCII table (0-127). Higher entries will cause issues as they are converted to char.
void ReadSerialString(out string dataBuffer)
int transactionSize = port.BytesToRead;
int read = 0;
byte[] tempBuffer = new byte[transactionSize];
while (read < transactionSize)
int thisRead = port.Read(tempBuffer, 0, transactionSize - read);
dataBuffer += new string(System.Text.Encoding.UTF8.GetChars(tempBuffer));
read += thisRead;
if(read < transactionSize)
for(int i = 0; i < transactionSize; i++)
tempBuffer[i] = 0; //Clear out buffer in case we read multiple times
hello,
thx for reply
how I can use this code( void ReadSerialString(out string dataBuffer) )?
my code is :
using System.IO.Ports;
using System.Text;
namespace change_this_to_your_namespace
SerialPort UART = new SerialPort(“COM1”, 115200);
int read_count = 0;
byte[] rx_byte = new byte[1];
UART.Open();
// read one byte
read_count = UART.Read(rx_byte, 0, 1);
if (read_count > 0)// do we have data?
// create a string
string counter_string =
"You typed: " + rx_byte[0].ToString() + "\r\n";
// convert the string to bytes
byte[] buffer = Encoding.UTF8.GetBytes(counter_string);
// send the bytes on the serial port
UART.Write(buffer, 0, buffer.Length);
//wait...
Thread.Sleep(10);
thx
