We are building a project based on EMX (SoM) module.
From time to time it’s necessary to send some lightweight wireless data to a PC (with an XStick for example).
I guess the best solution is to use Xbee module ?
If so - which would be the best Xbee module to use in terms of libraries and connectivity ?
If the price of XBee is not a problem then it’s a good choice. For your project you could use simplier (and cheaper) solutions like Nordic nRF24L01+ but you would have to find a USB version for your PC. With XBee you have the XStick. Check out the version you want to buy (or have already)
One is for Series 1 modules (802.15.4) and the other is for Series 2 (Zigbee). All of them can be controlled using this library
With XBee the communication with PC is simplier because those modules use UART. XStick is essentialy an XBee and UART to USB converter packed in a dongle. With Noridc a similar solutions requires a CPU in the dongle that will translate talk to PC thru USB and to Noridc thru SPI. If you want to go with Nordic modules i suggest you buy an extra FEZ board that wil be used by your PC as the adapter. If however you want to go with XBee i don’t recommend buying the XStick because it’s expensive and hard to get. Its only advantage is that it looks nice What i suggest for the PC endpoint is this:
when you add XBee to it you will have the same as XStick but for lower price. You will end up having a serial port in your PC that will allow you to communicate with XBee (also upgrade its firmware). You can use the library I mentioned to write code that will work both on PC or FEZ.
Thank you much for your answer. So I think I’ll get Xbee. The price doesn’t seems to be that different from Nordic and looks like more standard solution.
