I am attempting to broadcast on my subnet broadcast address 100.100.255.255 rather than 255.255.255.255. Below is my test code. If I use 255.255.255.255 I see it just fine, but if I use 100.100.255.255 I get an ARP request “who has 100.100.255.255? Tell 100.100.1.5”. Am I doing something wrong in my code or is this an issue with the new 4.2 network stack?
Looks like my issue might be related to this
http://www.tinyclr.com/forum/topic?id=10532
//Uncomment just one
//string broadcastIP = "255.255.255.255";
string broadcastIP = "100.100.255.255";
// Start Ethernet (EMX)
EthernetBuiltIn Ethernet = new EthernetBuiltIn();
Ethernet.Open();
NetworkInterfaceExtension.AssignNetworkingStackTo(Ethernet);
NetworkInterface[] networkInterfaces = NetworkInterface.GetAllNetworkInterfaces();
networkInterfaces[0].PhysicalAddress = new byte[] { 0x00, 0x1A, 0xF1, 0x00, 0x42, 0x0D };
networkInterfaces[0].EnableStaticIP("100.100.1.5", "255.255.0.0", "100.100.0.1");
// Set up UDP endpoint
EndPoint localEndPoint = new IPEndPoint(IPAddress.Parse("100.100.1.5"), 28598);
EndPoint remoteEndPoint = new IPEndPoint(IPAddress.Parse(broadcastIP), 28599);
Socket serverSocket = new Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);
serverSocket.SetSocketOption(SocketOptionLevel.Socket, SocketOptionName.ReuseAddress, true);
serverSocket.SetSocketOption(SocketOptionLevel.Udp, SocketOptionName.Broadcast, true);
serverSocket.Bind(localEndPoint);
byte[] sendData = new byte[] { 0x1E, 0x10, 0xFF, 0xFF };
for (; ; )
serverSocket.SendTo(sendData, remoteEndPoint);
Thread.Sleep(1000);
@ andre.m - I just tried this (see below) and still getting an ARP request.
string broadcastIP = "192.168.0.255";
Ethernet.Open();
networkInterfaces[0].EnableStaticIP("192.168.0.2", "255.255.255.0", "192.168.0.1");
EndPoint localEndPoint = new IPEndPoint(IPAddress.Parse("192.168.0.2"), 28598);
for (; ; )
Thread.Sleep(1000);
@ andre.m - Same thing. Still getting an ARP request
@ andre.m - Tried adding a few other lines (see below). Still nope. I was going to send out for this issue last week but I figured I would poke around the forums all weekend in search of an answer. Did not realize 4.2 has a new networking framework.
Thank you for your help andre. This answers my question but should I mark this as solved since it is a bug?
Dan
serverSocket.Connect(remoteEndPoint);
as well as changing send to sendto
//serverSocket.Send(sendData, 0, sendData.Length, SocketFlags.Broadcast);
@ andre.m - Just double checking. Thanks for the quick replies. Much appreciated.
I see this workissue on codeplex. It’s been closed for awhile but perhaps it’s related?
http://netmf.codeplex.com/workitem/754
EDIT
I meant this link http://netmf.codeplex.com/workitem/1166
@ andre.m - You must have read my mind. I just gave the emulator a try and it’s working fine in there
Just had to remove some of the GHI specific lines and change the local endpoint. Below is what I ran in the emulator.
EndPoint localEndPoint = new IPEndPoint(IPAddress.Parse("100.100.100.254"), 28598);
serverSocket.SetSocketOption(SocketOptionLevel.Socket, SocketOptionName.Broadcast, true);
for (; ; )
Thread.Sleep(1000);
Using ostinato, I injected an ARP reply for 100.100.255.255 to resolve to FF:FF:FF:FF:FF:FF and it started working properly. Obviously once this ARP record expires or the device is rebooted, it will stop working.
-Dan Powers
Not exactly in this case as the TCP/IP stack used in NETMF is not used by the emulator. We will run few test on multiple devices to see if it is related to a single device or it is on all devices. My guess it will be on all devices and will report to Microsoft if that is the case.
@ Gus - Thanks Gus! I’ll just work around the issue for now by using 255.255.255.255. It should work for my application for the time being.
Thanks guys,
Dan Powers
@ Gus - looks like the issue is resolved in 4.2.10.0. Marking it as answered.
