EMX - Touch screen issue when not debugging via USB1
Hi All,
I have a strange issue with the EMX module.
I have designed & fabricated a PCB for my home automation system, the EMX module is mounted in the centre and ethernet, USB Device & SD card components are around the outside. There is also a 60 pin IO header for extensibilty. On the reverse side of the PCB is a 40 pin connector which connects to another PCB which is responsible for the LCD FPC connectors and backlight circuit. I;m using the standard sharp 480x272 LCD touch screen.
When im debugging from VS2010 through USB1 the touch screen functions correctly - i can receive and consume touch events.
However - when the PCB is not connected to USB - and therefore powerd via PoE - the touch screen doesnt report any touch events.
Is there something specific about debug mode, and maybe some additional configuration I need to supply for this to work standalone?
I’m not sure at the moment if this is software or hardware related…
Any help you guys have would be much appreciated…
        var application = new Program();
        //Configure Touch
        Touch.Initialize(application);
        SetTouchConfiguration();
        Touch.ActiveTouchPanel.Enabled = true;
        //Configure Display
        var lcdBacklight = new OutputPort(EMX.Pin.IO48, true);
        lcdBacklight.Write(true);
        //Configure Network
        SetNetworkConfiguration();
        //Start Database
        var tDatabase = new Thread(StartDatabase);
        tDatabase.Start();
        application.Run(application.CreateWindow());
    static void SetTouchConfiguration()
        var sx = new short[5] { 240, 48, 48, 432, 432 };
        var sy = new short[5] { 136, 26, 246, 246, 26 };
        var cx = new short[5] { 478, 189, 169, 781, 790 };
        var cy = new short[5] { 481, 238, 741, 767, 231 };
        Touch.ActiveTouchPanel.SetCalibration(5, sx, sy, cx, cy);
Using code tags will make your post more readable. This can be done in two ways:[ol]
Click the “101010” icon and paste your code between the
 tags or...
Select the code within your post and click the "101010" icon.[/ol]
(Generated by QuickReply)
Where in the code do you subscribe for the events?
Hi Architect,
Thanks for the reply - and for the code paste tip… :o)
Here is my button class…
#region Using Directives
using Microsoft.SPOT.Input;
 #endregion
namespace Intellitouch.UI.Controls
    public class ControlButton : ContentControl
        #region Private Members
        private readonly Border _border;
        private int _borderWidth;
        private bool _isFocused;
        private bool _isPressed;
        private Brush _bground;
        private Brush _borderBrush;
        private Brush _pressedBackground;
        private Brush _pressedBorderBrush;
        #endregion
        #region Public Events
        public event EventHandler Click;
        #endregion
        #region Construct
        public ControlButton(UIElement child)
            _border = new Border
                Background = new SolidColorBrush(Colors.White),
                BorderBrush = new SolidColorBrush(Colors.Black),
            PressedBackground = Background;
            PressedBorderBrush = new SolidColorBrush(Colors.Gray);
            _border.SetBorderThickness(_borderWidth);
            Child = child;
            base.Child = _border;
        #endregion
        #region Public Properties
        public bool IsPressed
            get { return _isPressed; }
            set
                if (value != _isPressed)
                    _isPressed = value;
                    if (_isPressed)
                        _border.Background = PressedBackground;
                        _border.BorderBrush = PressedBorderBrush;
                        _border.Background = Background;
                        _border.BorderBrush = BorderBrush;
        public new Brush Background
            get { return _bground; }
            set
                _bground = value;
                if (!IsPressed)
                    _border.Background = _bground;
        public Brush BorderBrush
            get { return _borderBrush; }
            set
                _borderBrush = value;
                if (!IsPressed)
                    _border.BorderBrush = _borderBrush;
        public Brush PressedBackground
            get { return _pressedBackground; }
            set
                _pressedBackground = value;
                if (IsPressed)
                    _border.Background = value;
        public Brush PressedBorderBrush
            get { return _pressedBorderBrush; }
            set
                _pressedBorderBrush = value;
                if (IsPressed)
                    _border.BorderBrush = value;
        public int BorderWidth
            set
                _borderWidth = value;
        public new UIElement Child
            get { return _border.Child; }
            set
                _border.Child = value;
        #endregion
        #region Private Methods
        protected virtual void OnClick()
            if (Click != null)
                Click(this, new EventArgs());
        #endregion
        #region Overrides
        protected override void OnTouchDown(TouchEventArgs e)
            base.OnTouchDown(e);
            _isFocused = TouchCapture.Capture(this);
            IsPressed = _isFocused;
        protected override void OnTouchMove(TouchEventArgs e)
            base.OnTouchMove(e);
            if (_isFocused)
                int x, y;
                e.GetPosition(this, e.Touches.Length - 1, out x, out y);
                IsPressed = x >= 0 && x <= ActualWidth && y >= 0 && y <= ActualHeight;
        protected override void OnTouchUp(TouchEventArgs e)
            base.OnTouchUp(e);
            if (_isFocused)
                int x, y;
                IsPressed = false;
                _isFocused = !TouchCapture.Capture(this, CaptureMode.None);
                e.GetPosition(this, 0, out x, out y);
                if (x >= 0 && x <= ActualWidth && y >= 0 && y <= ActualHeight)
                    OnClick();
        #endregion
