Hi
The EMX module has a 40 way 0.5 mm header with no connector soldered. Is this compatible with the header on the EM (Embedded Master) module? I’m planning to solder a connector on my EMX module and use it with a LQ043T3DX02 LCD (the LCD is pin to pin compatible with the connector on the EM module).
If the header is compatible with the EM header, is it safe to connect +5V to EMX pin 38? in the EM design, pin 38 was routed to the LCD’s +5V pins but in the EMX module is marked as NC.
I see (in the downloads section) that LQ043T3DX02 was supported by the EM module via the 40 pin header but can’t find any configuration code. I wrote the config code below but just wanted to double check it with a known working code.
lcdConfig.PriorityEnable = false;
lcdConfig.OutputEnableIsFixed = true;
lcdConfig.OutputEnablePolarity = true;
lcdConfig.PixelClockDivider = 8; //9MHz clock
lcdConfig.PixelPolarity = false; //falling edge
//clocks per line = 525
lcdConfig.HorizontalSyncPolarity = false;
lcdConfig.HorizontalSyncPulseWidth = 41;
lcdConfig.Width = 480;
lcdConfig.HorizontalBackPorch = 2;
lcdConfig.HorizontalFrontPorch = 2;
//lines per frame = 286
lcdConfig.VerticalSyncPolarity = false;
lcdConfig.VerticalSyncPulseWidth = 10;
lcdConfig.Height = 272;
lcdConfig.VerticalBackPorch = 2;
lcdConfig.VerticalFrontPorch = 2;
