I’m working on some UI code that can be done just fine in the emulator, in fact it would be quicker to debug and run. Rather than comment out my hardware-specific code is there a way to use the standard C# compilier directives to detect if the target is the Microsoft Emulator?
You’d have to do it yourself, because (if I understand correctly) the compiler doesn’t know what the target is, unless you tell it (by setting the #define in project properties).
I had forgotten a bit about how the preprocessor symbols work. I simply just checked the Define DEBUG constant checkbox and then set that configuration to use the emulator. The release configuration uses the actual hardware. Then in the code I just check the DEBUG constant.
