Downgrading NetMicroframework Firmware
Has anybody experience in downgrading bootloader and firmware ?
(Hardware: G400D / TH)
How stable/how secure?
regards
While it can be done, it is not recommended. Why do you want to use an older software?
@ Gus - for testing older project configurations without elmiminating possible side effects
@ hweinfurterAAEj4i5 - then using an older firmware should be no problem.
what do you think about bootloader compatibility within “NETMF v4.3 SDK” stream.
are there any differences? do I really have to update also all loader, if I step back with application firmware version?
The best approach is to load the loader and the firmware from your installed sdk
