Downgrading G120 firmware
I’ve made an application on EMX and netmf 4.1. Now I want to replace the EMX with a G!20 module and test it with that application. The G120 module has firmware 4.3. Is it possible to ‘downgrade’ that firmware to 4.1?
Peter
unlikely you can go back to 4.1. G120 hasn’t been around that long, and as far as I can recall it would have been 4.2 as a minimum that GHI released the first firmware for that platform, perhaps even 4.3 only. You absolutely need to have GHI to have released a production SDK with the firmware so you can deploy - on my quick look in the 2016 R1 SDK it looks like there’s only a 4.3 firmware for G120 included.
Thank you Brett for your reply.
I just want to know whether my application runs on G120 or not.
The problem is changing form 4.1 to 4.3 involves a lot of code changes (I think) and I haven’t got the time at the moment.
Maybe someone from GHI will react.
What Brett said is true plus we only support 4.3 today. However, our consulting services are available to help in porting the code if needed.
