Hello, a simple question: How do i downgrade Fez cerbot 1.3 firmware from 4.37 to 4.2 ?
I see your simple question and counter with my own. Why?
In general, downgrading has risks. There are issues potentially addressed that you will no longer benefit from. There are gotchas with existing projects that you may fall foul of. The first step in doing that is to obtain the SDK that you want that has the firmware in it from the older SDK repository [url]https://www.ghielectronics.com/support/netmf/sdks[/url]. Then you should extract the firmware (install it on a temporary OS for example) and go through the normal update process.
@ Martizs - I’d support Brett’s “Why?”
Erverything is ported to 4.3. You can have a look at this project for 4.3.
https://www.ghielectronics.com/community/codeshare/entry/1047
