Hello
I´m tring to connect both the lcd and the ethernet shiled to the domino hardware, but i found that the lcd uses SPI1 and D9, D10 signals; so I will use SPI2 to the ethernet, but wich DI pins should I use for CS and reset ?
My code … WIZnet_W5100.Enable(SPI.SPI_module.SPI2,(Cpu.Pin)FEZ_Pin.Digital.Di??,(Cpu.Pin)FEZ_Pin.Digital.Di??, true); …
You can use any unused digital pins for CS and reset. That is why you need to specify your choice in the enable.
Are you using shields from GHI catalog?
I´m using the Wiznet W5100 from seeedstudio and the LCD & Keypad Shield from the hardware catalog, thanks
