What is the latest firmware version ?
SDK Version 1.0.17 October 06, 2011
•USBizi (FEZ Mini, FEZ Domino, FEZ Rhino, FEZ Panda) V 4.1.7.0
•GHI NETMF Library V 4.1.7.0
Check the Release note always for this
The best way to check is release notes link under “Downloads & Tutorials”:
Thanks all for reply…
Ok, I think I downloaded right file but something else goes wrong.
I try to update it with USBiziUpdater.exe
First: Ping --> Connecting… TinyCLR
Think return is ok?
Then I push buttons: LDR ON, RESET ON / OFF, LDR OFF
Right sequence?
UPDATE:
At first, responce is:
Connecting to device…
USBizi found at Port#: COM4
Cannot connect to the device! Follow steps 1 to 3
Then again steps 1 to 3
UPDATE:
Confirmation dialog shows: All data will be deleted…
And finaly:
Device will be updated automatically! DO NOT disconnect or turn off the device!
Erasing…
Error while connecting to the device. Try again!
Disconnecting COM4
Rebooting…
Firmware updated sucessfully. Version number: 4.1.3.0
Updating Firmware is done!
The file USBizi_CLR.GHI is datet oct. 6 2011
4.1.3 is an old version, which means you need to install the latest GHI SDK on your computer BEFORE you run the updater. Current version is 4.1.7. The updater looks in the default install folder on your PC for this. You can change that to whatever folder contains the latest files.
Try updating again and see if you still get the “Error while connecting to the device. Try again!” message. If so, you probably have a flaky cable or the board is under powered, USB ports on PCs or laptops sometimes don’t provide adequate power. Try with a separately powered USB hub.
Thank you ransomhall, comment about flaky USB cabel do the trick. I change cabel and now its work ok.
Now its updatet to 4.1.7.0
