Hello,
Does anyone know of a display that connects via JST3AA wire.
Contact this company http://www.inexglobal.com
and tell them you need this http://www.ghielectronics.com/catalog/product/144
Thanks,
That inexglobal.com link does not work :o
it’s the correct link, must be a site specific issue
Well if the site does not work , how do I notify the company?
I just bought a serial LCD and soldered a JST cable to it. Took longer to warm up the iron then do the job.
Sparkfun have serial LCDs.
I am using the 20x4 Sparkfun LCD. Works great.
Well I found this:
http://www.sparkfun.com/products/9393
Does anyone know if there are drivers for these on TinyClr?
Thanks,
From SF for the one you picked: “Communication with SerLCD requires 5V TTL serial…” . That will not work.
[edit] well, as Mike points out, it probably will work just fine.
This is what you want: http://www.sparkfun.com/products/9066 . There are several similar ones with varying colors. Make sure it is 3.3V TTL.
@ Eric
I thought 3.3V into a 5V TTL is fine. The one threshold is around 2V?
@ Mike - Correct, but purchasing a 5V TTL may lead to an incorrect assumption by our self proclaimed n00b. Better to match specs by knowing what a FEZ actually outputs for a TTL voltage.
@ ransomhall
Thanks, as I am a beginner are there any drivers for that link that you gave me?
Thanks,
Gus posted the link above.
I think you are finding difficulties because you are not searching enough not because you are a beginner. Have you tried to search code share for “serial LCD”? Have ave you searched the same on sparkfun? I answered your question with a link and you are still asking where it is
We are always here to help but please try to look for answers first.
