I have had my ENC28 (v1.1) for awhile now, but it has not had much use since I have mostly used the Spider with the J11D module for networking. Now I have tried the ENC28 on my Hydra and Cerb, both with the Ethernet Firmware loaded but I have had no joy.
The ENC28 network lights do not even light up. I have the module plugged into socket 6 on my Cerberus and I have tried the following
- Powered USB
- External Power from Wall Wart
- PC USB
- Changed Gadgeteer Cable to one that is known to be working with another module
I can set the network config in MFDeploy with no problem, but any attempt to work with the ENC28 fails. For example sending a UDP message fails with an Exception, all the exception tells me is that it is a SocketException with no other detail at all other than an HResult of 0xFF000000.
And finally, the device capabilities of the cerb.
HalSystemInfo.halVersion: 4.2.0.0
HalSystemInfo.halVendorInfo: Copyright Oberon microsystems, Inc.
HalSystemInfo.oemCode: 255
HalSystemInfo.modelCode: 0
HalSystemInfo.skuCode: 65535
HalSystemInfo.moduleSerialNumber: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
HalSystemInfo.systemSerialNumber: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
ClrInfo.clrVersion: 4.2.0.0
ClrInfo.clrVendorInfo: Copyright Oberon microsystems, Inc.
ClrInfo.targetFrameworkVersion: 4.2.0.0
SolutionReleaseInfo.solutionVersion: 4.2.3.2
SolutionReleaseInfo.solutionVendorInfo: Copyright © GHI Electronics, LLC
SoftwareVersion.BuildDate: Oct 23 2012
SoftwareVersion.CompilerVersion: 410462
FloatingPoint: True
SourceLevelDebugging: True
ThreadCreateEx: True
LCD.Width: 0
LCD.Height: 0
LCD.BitsPerPixel: 0
AppDomains: True
ExceptionFilters: True
IncrementalDeployment: True
SoftReboot: True
Profiling: False
ProfilingAllocations: False
ProfilingCalls: False
IsUnknown: False
