DisplayN18 on Cobra II console app
Hi all,
Anyone is using the DisplayN18 module on a Cobra II console application? If so, what’s the correct way to init this?
@ David@ Leclanche - While we do not provide a non-Gadgeteer example for the DisplayN18, you can always port the Gadgeteer driver yourself: https://bitbucket.org/ghi_elect/gadgeteer/src/5c8596ffc9f6cf7fd80bcfb8fbb1906e732c312c/Modules/GHIElectronics/DisplayN18/DisplayN18_43/DisplayN18_43.cs?at=master&fileviewer=file-view-default
Is it not possible to add the reference to the gadgeteer assembly and use this from a console application?
No.
The gadgeteer drivers interface with the gadgeteer framework.
If you include the Gadgeteer libraries it depends on - but then you may as well just use a Gadgeteer app to start with.
