Hello, can anyone point me where to find code for Display T43 to use touch function?
Thanks in advance for help.
Welcome to the forum!
Check this document:
thanks for your fast reply. I saw this document and it show how to draw on the screen and write text but there is no information about the touch feature.
@ Tati - Check Example 3. It shows how to subscribe to touch events and process them in the handler method.
thanks, I will try that
@ Architect - I saw this example but it target Non-Gadgeteer so it conflict with the code I wrote. Could you please guide me how to add touch with Gadgeteer way
@ Tati - What happens if you try this:
In ProgramStarted:
display_T43.WPFWindow.TouchDown += WPFWindow_TouchDown;
And the handler itself:
void WPFWindow_TouchDown(object sender, Microsoft.SPOT.Input.TouchEventArgs e)
int x, y;
e.GetPosition(display_T43.WPFWindow, 0, out x, out y);
Debug.Print("X: " + x.ToString + " Y: " + y.ToString());
