Hello,
I’m trying to bring a bitmap to a TE35 with a Spider motherboard. I use VS 2012 with the latest SDK, programming in VB.net. Can anyone help me? Sorry for my english
Here is the code:
Public Sub ProgramStarted()
Dim bild As New GT.Picture(Resources.GetBytes(Resources.BinaryResources.Ladewagen), Gadgeteer.Picture.PictureEncoding.BMP)
Debug.Print(“Program Started”)
lcd.SimpleGraphics.DisplayImage(bild.MakeBitmap, 0, 0)
End Sub
There is always the error:
Found debugger!
Create TS.
Loading start at a0e00000, end a0e2f494
Assembly: mscorlib (4.3.1.0) Assembly: Microsoft.SPOT.Native (4.3.1.0) Assembly: Microsoft.SPOT.Security.PKCS11 (4.3
.1.0) Assembly: System.Security (4.3.1.0) Assembly: Microsoft.SPOT.Hardware (4.3.1.0)
Assembly: Microsoft.SPOT.Graphics (4.3.1.0) Assembly: Microsoft.SPOT.TinyCore (4.3.1.0)
Assembly: Microsoft.SPOT.IO (4.3.1.0) Assembly: System.IO (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.3.1.0) Assembly: Microsoft.SPOT.Touch (4.3.1.0)
Assembly: Microsoft.SPOT.Ink (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.3.1.0)
Attaching deployed file.
Assembly: Microsoft.VisualBasic (1.0.0.0) Attaching deployed file.
Assembly: Gadgeteer (2.43.1.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.DisplayTE35 (4.3.3.0) Attaching deployed file.
Assembly: GHI.Hardware (4.3.3.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.Joystick (4.3.3.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.USBClientDP (4.3.3.0) Attaching deployed file.
Assembly: GHI.Usb (4.3.3.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.3.1.0) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZSpider (4.3.3.0) Attaching deployed file.
Assembly: Ztrol_2_0 (1.0.0.0) Resolving.
GC: 1msec 36648 bytes used, 7303020 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 7303020 bytes
Type 17 (ASSEMBLY ): 34788 bytes
Type 1E (BINARY_BLOB_HEAD ): 1332 bytes
Type 28 (MEMORY_STREAM_HEAD ): 36 bytes
Type 29 (MEMORY_STREAM_DATA ): 396 bytes
GC: performing heap compaction…
Ready.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\mscorlib.dll” geladen, Symbole geladen.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Native.dll” geladen, Symbole geladen.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.dll” geladen, Symbole geladen.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Security.PKCS11.dll” geladen, Symbole geladen.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Security.dll” geladen, Symbole geladen.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Graphics.dll” geladen, Symbole geladen.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.TinyCore.dll” geladen, Symbole geladen.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.IO.dll” geladen, Symbole geladen.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.IO.dll” geladen, Symbole geladen.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll” geladen, Symbole geladen.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll” geladen, Symbole geladen.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Touch.dll” geladen, Symbole geladen.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Ink.dll” geladen, Symbole geladen.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll” geladen, Symbole geladen.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.VisualBasic.dll” geladen, Symbole geladen.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.dll” geladen, Symbole geladen.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3\le\Gadgeteer.dll” geladen, Symbole geladen.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\DisplayTE35\NETMF 4.3\le\GTM.GHIElectronics.DisplayTE35.dll” geladen, Symbole geladen.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.3 SDK\Libraries\le\GHI.Hardware.dll” geladen
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\Joystick\NETMF 4.3\le\GTM.GHIElectronics.Joystick.dll” geladen, Symbole geladen.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\USBClientDP\NETMF 4.3\le\GTM.GHIElectronics.USBClientDP.dll” geladen, Symbole geladen.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.3 SDK\Libraries\le\GHI.Usb.dll” geladen
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Mainboards\FEZSpider\NETMF 4.3\le\GHIElectronics.Gadgeteer.FEZSpider.dll” geladen, Symbole geladen.
“Microsoft.SPOT.Debugger.CorDebug.dll” (Verwaltet): “C:\Users\Herbert\Documents\Visual Studio 2012\Projects\Ztrol_2_0\Ztrol_2_0\bin\Release\le\Ztrol_2_0.exe” geladen, Symbole geladen.
Der Thread ‘’ (0x2) hat mit Code 0 (0x0) geendet.
Using mainboard GHI Electronics FEZ Spider version 1.0
Program Started
#### Exception System.NotSupportedException - CLR_E_NOT_SUPPORTED (1) ####
#### Message:
#### Microsoft.SPOT.Bitmap::.ctor [IP: 0000] ####
#### Gadgeteer.Picture::op_Explicit [IP: 000c] ####
#### Gadgeteer.Picture::MakeBitmap [IP: 0004] ####
#### Ztrol_2_0.Ztrol_2_0.Program::ProgramStarted [IP: 001e] ####
Eine Ausnahme (erste Chance) des Typs “System.NotSupportedException” ist in Microsoft.SPOT.Graphics.dll aufgetreten.
Eine nicht behandelte Ausnahme des Typs “System.NotSupportedException” ist in Microsoft.SPOT.Graphics.dll aufgetreten.
WARN: Total initialization time exceeds 10 seconds.
: ProgramStarted is blocking execution, which means events and timers will not run properly.
: Make sure not to use blocking code such as while(true) - use a GT.Timer instead.
Uncaught exception
Der Thread ‘’ (0x1) hat mit Code 0 (0x0) geendet.
Das Programm “[2] Micro Framework application: Verwaltet” wurde mit Code 0 (0x0) beendet.
[line] [title][/title]
