Dispaly TE 35 doesn't show the image in the full screen
I am using the code below to use DispalyTE 35 to show the image captured by SerialCameraL1. I copied the code from the Forum topic:Troubles with Serial Cam L1, T43 Module.
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace GadgeteerserialCameraL1
    public partial class Program
        Bitmap bmap;
            bmap = new Bitmap(displayTE35.Width, displayTE35.Height);
            new Thread(VideoStreaming).Start();
       void VideoStreaming()
            serialCameraL1.StartStreaming();
            Debug.Print("streaming started");
           while(true)
               Thread.Sleep(500);
               if (serialCameraL1.NewImageReady)
                   Debug.Print("new image ready");
                   var image = serialCameraL1.GetImage();
                   bmap.DrawImage(0, 0, image, 0, 0, displayTE35.Width, displayTE35.Height);
                  bmap.Flush();
                   serialCameraL1.StopStreaming();
It works fine when I first debug it, Display TE35 shows the full screen image, but after I tried to save the image into the sdCard unsuccessfully,
I tried to run the codes again for just displaying the image, Display TE35 never gives me full screen image. It only shows the image in the quarter of the screen. Does any one can help me, what happened?
Many thanks.
If you breakpoint after you capture the image, what is the resolution of the image? It is possible that it is less than the LCD size.
could it be that you’ve somehow reset the image size of the camera in your other app using ImageResolution() ?
@ Dave McLaughlin - Hi,
thanks.
The captured image is 640 × 480,larger than the screen resolution 320× 240.
@ Brett - Hi,
thanks , when I use the code
this.serialCameraL1.ImageResolution = GTM.SerialCameraL1.Resolution.VGA;
it works fine now ;D
