hullie
1
I’ve been looking for a setting to disable debug info in the output window
Once in a while info like this is passing:
GC: 3msec 22680 bytes used, 41700 bytes available
Type 0F (STRING ): 876 bytes
Type 11 (CLASS ): 1800 bytes
Type 12 (VALUETYPE ): 48 bytes
Type 13 (SZARRAY ): 1956 bytes
Type 15 (FREEBLOCK ): 41700 bytes
Type 17 (ASSEMBLY ): 12984 bytes
Type 18 (WEAKCLASS ): 48 bytes
Type 19 (REFLECTION ): 48 bytes
etc.etc.
How to disable this?? because it’s interfering with the debug info I want to see.
Best regards,
Hullie
cypher
2
You have to insert the following line of code
BR
Marc
hullie
3
Hi Marc,
Thanks a lot. That solved it.
I was looking in the wrong place, in Visual studio itself, instead of adding something to the code.
Best regards,
Hullie
Don’t you think that this one could be in a good place in a “Programming FAQ” or “Programming : tips & tricks ?”
hullie
5
Yes, that would be a good idea.
I did use the search button, but the search didn’t return any results.
Best regards,
Hullie
cypher
6
I think the forum is not apropiate for this kind of FAQ.
As hullie said , he use the search button, but no result.
So there must be some kind of tags for search like on fezzer.com
Or the wiki will be also an option. When I have some questions I ask wikipedia
Cypher, I didn’t mention any specific location for this
It should be visible, though, so you don’t have to search for the FAQ to then search for your answer
cypher
8
Ohh , I thought you want open a FAQ section here in the forum :wall:
Ok, let’s start a section in the wiki :whistle:
