Im having difficulty with a small web server project Ive been working on. My main objective is to set up a server on the Cerberus which can serve files from the SD card. Almost everything works well, except for the actual serving. I am using MNMF version 4.2, and updated the firmware from the very latest version (July 23). Heres the program start, just for reference:
public partial class Program
//Set methods to handle SD card in/out events...
sdCard.SDCardMounted += new SDCard.SDCardMountedEventHandler(sdCard_SDCardMounted);
sdCard.SDCardUnmounted += new SDCard.SDCardUnmountedEventHandler(sdCard_SDCardUnmounted);
//Start the network...
string ip = "";
Debug.Print("Network Startup");
Microsoft.SPOT.Net.NetworkInformation.NetworkInterface[] ethintf = Microsoft.SPOT.Net.NetworkInformation.NetworkInterface.GetAllNetworkInterfaces();
foreach (Microsoft.SPOT.Net.NetworkInformation.NetworkInterface nif in ethintf)
Debug.Print("Intf: " + nif.IPAddress);
ip = nif.IPAddress;
if (ip == "")
Debug.Print("ERROR: No ethernet found!"); //TODO: Recover and retry
return;
//Then network is up, now set up the handler for web events and wait fore the fish to bite...
WebEvent webEventProcess = WebServer.SetupWebEvent( "index.html" );
webEventProcess.WebEventReceived += new WebEvent.ReceivedWebEventHandler( webEventProcess_WebEventReceived);
WebServer.StartLocalServer(ip, 80);
So far so good. SD card detection works well, and I can dump out the available files from the ‘mounted handler (which kicks off on program start and also mount the card). The networking seems very solid. My issue is in the web handler below. Specifically, when I use Respond() to try to serve the file, I get error messages, despite the fact that the file does get sent.
void webEventProcess_WebEventReceived( string path, WebServer.HttpMethod http, Responder responder )
ContentType = “text/plain”;
GT.StorageDevice fileReference = sdCard.GetStorageDevice();
if (System.IO.File.Exists("\\SD\\" + path))
Debug.Print( "yep, we can find it...");
try
responder.Respond( System.IO.File.ReadAllBytes( "\\SD\\"+ path ), ContentType);
System.Threading.Thread.Sleep(1000);
Debug.Print("File served...");
catch (Exception e)
Debug.Print("Exception while sending file");
throw e;
I think the issue is related to the use of ReadAllBytes() as a parameter, which should open the file, read the contents (into some secret place) and then close it again. This seems like it should work, but I get the following massage in Debug:
Failed allocation for 441 blocks, 5292 bytes
The program limps along, and tries to serve a second file. This time Debug reports:
Failed allocation for 198 blocks, 2376 bytes
Failed allocation for 172 blocks, 2064 bytes
A first chance exception of type ‘System.IO.IOException’ occurred in Microsoft.SPOT.IO.dll
A first chance exception of type ‘System.IO.IOException’ occurred in NetServe.exe
Error invoking method “Gadgeteer.Networking.WebEvent” (check arguments to Program.BeginInvoke are correct)
At this point program execution recedes deep into the jungle, and must be restarted. I have re-updated the boot loader and NMF 4.2 SDK files a couple of time just to be sure all is well.
Its likely that ReadAllBytes() is setting up some buffer somewhere, and doesnt have enough space for the whole thing. Id like to send the file in chunks of 5K bytes, but havent found a good way to do it within the context of Gadgeteer.Networking.
Any suggestions?
