GHI sells the SMart Multicolor LED module on its website at:
https://www.ghielectronics.com/catalog/product/272
The image shows “version 1.2” and indeed this is the version of the 3 I received a few months ago.
Walterott.com in Germany, however, is selling a newer, “V2” version of this module here:
http://www.watterott.com/en/Multicolor-LED-v2
And if you look at the image there, it actually says version 2.1. And if you look at the specs, it is actually 1mm larger in each dimension (22mmx23mm) vs the 1.x (21mmx22mm). Also, the layout has changed, and there aren’t any big yellow rectangle components anymore.
What are the other differences? What does 2.0/2.1 have than 1.x doesnt?
Greater color gamut? Something more?
Is the version 1.2x going to run into some dangerous issues being 44 square millimeters smaller and using outdated yellow rectangle technology that the v2.1 version was created to prevent?
