I have a program that is failing to allocate a 4K block with 15K of free memory, so clearly I have some heap fragmentation. GC(true) does not fix it. I know I could pre-allocate the buffer earlier in the program life-cycle, but the max buffer size isn’t known for certain. I am using this buffer to load a .pe file from flash, so pre-allocating the buffer would set an artificial upper limit to the loadable modules.
My core question though is this : Debug.DumpHeap does not seem to exist in 4.3 (and according to the docs, not in 4.2 either), so what do you use to determine what you have in your heap at runtime? I don’t have access to GHI assys in this project, so I am looking for generic NETMF solutions, if any exist. How do you go about profiling your heap usage?
