DHCP Problem with VB.NET
Hi.
i have the spider-kit for a few day and testing it .
I’m using the J11D-Modul with
.EnableStaticIP(“192.168.2.210”, “255.255.255.0”, “192.168.2.1”)
and it works very well but wenn I change to
.EnableDhcp()
Do While .IPAddress = "0.0.0.0"
Debug.Print("Awaiting IP Address " )
Thread.Sleep(1000)
Loop
mvarIP = .IPAddress
Debug.Print("IP Address Granted: " + mvarIP)
End With
    GT.Networking.WebServer.StartLocalServer(mvarIP, 80)
nothing happens and I get no IP
I thing I need thomthing like
ethernet.UseDHCP()
but I can’t find thomething like that.
need for help…thanks
Daniel
thanks,
so I can stop trying…
Hi Daniel,
Just have a new post in my blog with some VB code… and works for me :wink:
http://msmvps.com/blogs/peplluis/archive/2012/12/11/vb-gadgeteer-webserver-sdk-4-2-qfe2-and-spider-premium-library-s.aspx
I hope this helps.
Best Regards,
PepLluis
Are you sure to have a DHCP properly configured (I mean that will give a IP corresponding to your mac address?)
@ PepLluis
Thanks, but it don’t works on my system…
I allways get the last static IP not a dhcp
what hardware do you use
@ Daniel,
My hardware is Spider with 4.2.7.0 and J11D
As Leforban say it depents of DHCP configuration,for example if you get the IP from a DHCP lease.
My doubt is understand when you say “always get the last static ip”… this ip is out of DHCP Range or is in the same segment?
A good chance is try with another router, or assign an static IP to check if all is working fine.
        ethernet.NetworkInterface.EnableStaticIP("192.168.1.35", "255.255.255.0", "192.168.1.1")
then in timer_tick you can show assigned IP adding “Debug.Print(ip.tostring)”
Regards,
PepLluis,
lets face it, most home class routers don’t do a great job of running DHCP; there’s many that have issues with certain NICs in PCs or similar. If you can, you can try another router.
I do not have a spider
