- Latest firmware 4.2.9.0
- No changes made to the code.
- Custom G120 + RS9110-N11-22-04 Rev 7 0F
- Interface: WiFi RS21
- Router Cisco EPC3925
Power the board On/OFF watched the results from COM1 using Teraterm
G120
Version: 4.2.9.0
Debug: COM1
LCD: 320x240
.NetMF v4.2.0.0
G120, Build Date:
Feb 13 2013 13:50:21
ARM Compiler version 410713
TinyCLR (Build 4.2.0.0)
Starting…
Created EE.
Started Hardware.
MSdbgV1y§Ç´Ãÿ%6Create TS.
Loading start at a0e856b0, end a0e9ce0c
Assembly: mscorlib (4.2.0.0) Assembly: Microsoft.SPOT.Native (4.2.0.0) Assembly: Microsoft.SPOT.Hardware (4.2.0.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1) Assembly: Microsoft.SPOT.Security.PKCS11 (4.2.0.0) Assembly: System.Security (4.2.0.0) Loading Deployment Assemblies.
Attaching deployed file.
Assembly: GHI.Premium.Hardware.G120 (4.2.9.0) Attaching deployed file.
Assembly: GHI.Premium.Native (4.2.9.0) Attaching deployed file.
Assembly: GHI.Premium.Net (4.2.9.0) Attaching deployed file.
Assembly: GHI.Premium.System (4.2.9.0) Attaching deployed file.
Assembly: G120DHCP (1.0.0.0) Attaching deployed file.
Assembly: System (4.2.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.2.0.0) Resolving.
GC: 1msec 314064 bytes used, 7025604 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 7025604 bytes
Type 17 (ASSEMBLY ): 15888 bytes
Type 1E (BINARY_BLOB_HEAD ): 298080 bytes
GC: performing heap compaction…
Ready.
RS9110 firmware version Number is 4.4.5
RS9110 driver version Number is 4.4.5
Wireless is: Connected
SSID: ikbenzoblij
WiFi Channel number: 11
Wireless Network Type: Access Point
MAC Address: E8:40:F2:C7:34:91
RSSI: -92dB
Wireless Security Mode: WPA2
New address for the Wireless Network Interface
Is DhCp enabled: True
Is DynamicDnsEnabled enabled: False
NetworkInterfaceType 71
Network settings:
IP Address: 192.168.1.63
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.1
Number of DNS servers:2
DNS Server 0:62.179.104.196
DNS Server 1:213.46.228.196
POWER DOWN
G120
Version: 4.2.9.0
Debug: COM1
LCD: 320x240
.NetMF v4.2.0.0
G120, Build Date:
Starting…
Created EE.
Started Hardware.
Ready.
#### Exception GHI.Premium.Net.NetworkInterfaceExtensionException - 0x00000000 (1) ####
#### Message:
#### GHI.Premium.Net.RS9110Helper::Join [IP: 0031] ####
#### GHI.Premium.Net.WiFiRS9110::Join [IP: 008b] ####
#### Program::Main [IP: 008b] ####
Uncaught exception
POWER DOWN
G120
Version: 4.2.9.0
Debug: COM1
LCD: 320x240
.NetMF v4.2.0.0
G120, Build Date:
Starting…
Created EE.
Started Hardware.
Ready.
WAIT 30 seconds POWER DOWN
G120
Version: 4.2.9.0
Debug: COM1
LCD: 320x240
.NetMF v4.2.0.0
G120, Build Date:
Starting…
Created EE.
Started Hardware.
Ready.
SSID: ikbenzoblij
RSSI: -80dB
Network settings:
POWER DOWN
G120
Version: 4.2.9.0
Debug: COM1
LCD: 320x240
.NetMF v4.2.0.0
G120, Build Date:
Starting…
Created EE.
Started Hardware.
Ready.
SSID: ikbenzoblij
RSSI: -84dB
Network settings:
POWER DOWN
G120
Version: 4.2.9.0
Debug: COM1
LCD: 320x240
.NetMF v4.2.0.0
G120, Build Date:
Starting…
Created EE.
Started Hardware.
Ready.
SSID: ikbenzoblij
RSSI: -88dB
Network settings:
POWER DOWN
G120
Version: 4.2.9.0
Debug: COM1
LCD: 320x240
.NetMF v4.2.0.0
G120, Build Date:
Starting…
Created EE.
Started Hardware.
Ready.
WAIT… POWER DOWN
