I’m trying ways to detect the PC kybd arrow keys (the four left/right/up down keys, NOT the ones on the numeric pad)…The following code works fine if I use .P or .Q keys, but does not work if I use .DownArrow or .UpArrow They are all listed as selectable enumerated choices…what’s wrong?
if (hhh==ddd.GetKeyState(USBH_Key.DownArrow)) arrowtype=1;
if (hhh == ddd.GetKeyState(USBH_Key.UpArrow)) arrowtype = 2;
@ Hoyt - I have been doing quite a bit of work with a USB connected keyboard recently and have not had any issues with the arrow keys. I quickly put together the following piece of code using the Gadgeteer infrastructure, the following worked for me. Do you see any differences with what you are doing?
namespace UsbKeyboardTest
public partial class Program
usbHost.KeyboardConnected += new UsbHost.KeyboardConnectedEventHandler(usbHost_KeyboardConnected);
void usbHost_KeyboardConnected(UsbHost sender, GHIElectronics.NETMF.USBHost.USBH_Keyboard Keyboard)
new Thread(
bool running = true;
while (running)
if (Keyboard.GetKeyState(GHIElectronics.NETMF.USBHost.USBH_Key.UpArrow) == GHIElectronics.NETMF.USBHost.USBH_KeyState.Down)
Debug.Print("Up arrow");
if (Keyboard.GetKeyState(GHIElectronics.NETMF.USBHost.USBH_Key.DownArrow) == GHIElectronics.NETMF.USBHost.USBH_KeyState.Down)
Debug.Print("Down arrow");
if (Keyboard.GetKeyState(GHIElectronics.NETMF.USBHost.USBH_Key.Escape) == GHIElectronics.NETMF.USBHost.USBH_KeyState.Down)
Debug.Print("Done.");
running = false;
}).Start();
Thanks.—your help led me to look again…I originally set some other code events to use CharDown…weeks later I wanted to use the arrow keys, but they only trigger KeyDown, so a simple change elsewhere fixed it. Chardown only triggers on ascii chars.
