One of my classroom surfaces is displaying the designer in XML, anyone know the setting to change to get it back to the module showing designer that I love showing off?
@ Duke Nukem - The designer, as in Visual Studio? Try the “Open With” command.
I have the solution open in Visual Studio 2013 and it compiles, deploys, debugs etc so it appears to be totally working other then the Gadgeteer Designer is shown as XML and not module images, so I suspect there is a setting somewhere that someone flipped that displays it as XML and I’m wondering how to change that back.
Agree with Mr. John Smith. Right-click the designer file, select “Open With…” and in the dialog select “Gadgeteer” and use the “Set as Default” button to set it back as the default editor.
