The latest release notes (SDK Version 1.0.11 October 15, 2010) assert “[italic]Note: RealTimeClock.IsTimeValid, in certain situations, does not perform as expected. It is no longer supported and always returns false. Please see RealTimeClock class for alternatives[/italic]”.
I’ve checked the RealTimeClock class for viable alternatives - it only supports [italic]GetTime, SetTime & SetAlarm[/italic] methods.
I just check to see if the time is less them something like 12/1/2010 (if it is not set correctly or resets, it is something like 1/1/2009, can’t remember exactly). If it is less then whatever date I put in there that I KNOW is in the past AND I have set it already, then I know I have an issue and need to reset the clock. Also, note that the Utility date and time resets to a much early date (2001?) and you always need to set it to the current RTC time on startup.
I fixed that by checking if some value in the battery-powered memory is equal to my magic value. If it is, the time is probably accurate as well. If not, it ask the user to set the date/time and write my magic value (e.g. ‘1234’)
